Question about Sewing Machines
Bobbin thread will not pick up nor will dog feed rise
I have a brand new kenmore and the bobbin thread will not pick up nor will the dog feed rise
  • polgara94611 Jul 06, 2008
    my kenmore will not pickkup the bobbin thread
My Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Posted on Jul 13, 2008
Bobbin is not picking up stitches. Also, it has a red cotton / fluff inside the spring of the bobbin. Should this be there?
Your bobbin and bobbin case should be clean of anything except the current thread. Also, be sure there is no other build-up of thread, lint, dust in the bobbin area, including the feed dogs.
Verify the machine is threaded correctly, the bobbin is inserted and turning the proper direction in the bobbin case.
Also, might try installing a brand new needle. If it still will not pick up the bobbin thread, then the machine may be out of time requiring service.
Sep 26, 2017 | Sewing Machines
How do I fix my machine so the upper thread connects to the bobbin?
I think that you are asking how to get the needle thread to go under the feed dogs and raise up with the bobbin thread also. I will use this as my guess.
1. Check the bobbin tension. Look on utube on how to do this. 2. Get new needle. It must be installed the right direction or the thread will not be picked up from the bobbin. 3. The top tension should be about four when doing this.
Mar 07, 2017 | Sewing Machines
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
Needle wont pick up bobbin thread
START WITH: SHARP NEEDLE (NEW), GOOD THREAD (NOT FUZZY-LONG STRANDS), ADJUST TENSION OF BOBBIN AND TOP.
1. Check the bobbin area and make sure the hook(pointed thing) and bobbin are all secure.
2. After you have adjusted the tension and reinstalled the bobbin: Extend three inches of thread from the bobbin.
3. After threading the top place the thread under the pressure foot and hold on to the thread. Turn the hand wheel towards you.
4. The needle has went under the throat plate (feed dogs plate) and begins to rise. You should feel the thread get caught and give a little resistance while you continue to turn the hand wheel.
5. The bobbin thread should come up with the needle thread.
6. If this hasn't taken place check to make sure the needle is inserted the right direction and totally pushed in. Retry again.
7. Look at your bobbin while turning the hand wheel. The needle thread should ride across the bobbin case and exit to the top of the machine again.
8. If these have not worked you will need to have your machine timed or the hook replaced.
ATTACHED IS A GUIDE FOR SETTING THE TENSION.
May 30, 2015 | White Sewing 2999 Mechanical Sewing...
When attempting to free motion quilt, bottom thread is not being picked up
You must lower the presser foot to use the free motion/darning foot.
Dec 04, 2013 | Brother Sewing Machines
My Kenmore Sewing Machine's needle is locked down
best suggestion try inserting new needle. cotton up the top suggests needle problem or incorrect top thread tension, this would effect the feed dog. Because thread is black and most recent use was with pink, the problem thread was already there perhaps in cavity above bobbin but below throat plate. I have had this happen and nothing will move, untill needle released. The bobbin holder tension may also need adjusting after the knots of black cotton are removed.
Nov 07, 2013 | Kenmore 15516 Mechanical Sewing Machine
I can not figure out how to raise the feed dog. the needle will not pick up the bobbin thread. Are these connected? thanks, Pauline paulinemccracken@gmail.com
Possibly. First put in a NEW needle. Then check when you rotate the handwheel to see if the hook is rotating around the bobbin case. If not, then probably the timing belt has come off. If the hook is rotating around the bobbin case and the feed dogs are not coming up, then check that you have the feed dogs engaged. Another sinario is that the timing is off just enough to not pick up the bobbin thread. Check for these symptoms first, and then well go from there.
Apr 26, 2011 | Singer 7462 Mechanical Sewing Machine
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
I have a Kenmore 14 stitch sewing machine that I haven't used in years - when I try to use it, the thread and bobbin thread seems to catch and it won't sew forward
take out the thread and bobbin. run the machine with the pressure foot up and watch the feed dogs (toothy things under the pressure foot that move the material through the machine). if they are not rising up above the plate, then you are sewing multiple stitches in one place and that's what spools up the threads. take the plate over the feed dogs off (it just pops up). get someone to remove the two screws holding the feed dog on (it's a torx #10). the piece the feed dogs was screwed to rides up and down on a short piece of polished rod under it. the rod has gummed up to its bearing. bright light, look for this and get some oil (3in1) on the rod above the bearing and force the feed dog mount up and down until it frees up.
Nov 29, 2009 | Kenmore 744-08BH Mechanical Sewing Machine
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
436 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
