Nintendo DSi White Console Logo
Posted on Dec 26, 2010
What is error code DSI internet connect 05110-1 mean
5 Related Answers
Anonymous
  • 110 Answers
  • Posted on Feb 09, 2010
SOURCE: i carnt connect to the internet by my dsi error
Im going to guess that your wireless router is a "wireless-n". If it is then you will have to go into your router settings and change it to either G and N or just G as the DSi does not support the wireless-n configuration.
If thats not your issue then give me a message and I will do my best to help you out.
Regards,
SOD69
Anonymous
  • 57 Answers
  • Posted on May 16, 2010
SOURCE: no internet dsi
This error code means that there was an error with the Auto-Obtain IP address setting. Review this information. NOTE: You may have to set the DNS to Auto-Obtain with the IP address.
If you don't use Auto-Obtain, check the WEP/WPA key. Make sure it matches with the key on the router.
Anonymous
  • 42 Answers
  • Posted on Jan 27, 2010
SOURCE: error code 051110-1 nintendo dsi
the dsi is trying to connect to connection file 2 ?? usually your home wireless connection is file 1 ? edit connection 2 with the same details that are in connection file 1 , or tell the dsi to use connection file 1 instead hope this helps ?? let me know
Anonymous
  • 10 Answers
  • Posted on Jul 23, 2010
SOURCE: how do i connect to the internet?
you need a wireless router and use the WFC setup tool to access it if you see the name or your router displayed (possibly with others) and the lock icon is blue you can use it without a WEP key, if the icon is red enter your WEP and proceed with a connection check, if the lock icon is grey it is unusable altogether. hope i helped.
Anonymous
  • 17 Answers
  • Posted on Jan 02, 2011
SOURCE: my dsi can not connect to internet always say
You have to go to (support.nintendo.com) and it would say on the left side fo your computer and where it says error code you type that number in and what kind of system it is and your language then click go and it will show you what you did wrong and how to fix it.
Error code 204970'
FROM THE SUPPORT WEBSITE......FOUND HERE
Nintendo DSi Shop Errors - Network ErrorThere was an issue with your connection to the Nintendo DSi Shop. Please try the following:
  1. Go into the Nintendo DSi menu (Wrench icon on the main menu screen.
  2. Select "Internet," and "Connection Settings."
  3. Erase your existing Internet Connection Settings and set up a new connection.
  4. Once you have established and tested a successful connection test, try the connection to the Nintendo DSi Shop again.
If you have verified that your Nintendo DSi or Nintendo DSi XL system's internet connection is working, then there could be a temporary issue with the Nintendo DSi Shop. Please wait awhile and try your connection again.
I hope this helps :D
2helpful
2answers
I am only getting error code 020100
  • This error code says that your DSI is not able to connect to the internet.
  • Move within 30 feet of your modem and make sure no phones or radios are interfering with your modem.
  • Also DSI will have trouble getting on the bet if you are on a hot spot because when other PC's drawing from the modem can effect the DSI's ability to connect to the modem.
  • Most of the time just moving closer and making sure no walls separate you and the modem fixes the problem.
Tony
My nintendo dsi pink console will not connect to the internet. It says no compatible access point in range. My error code says 051311.
You need to have an accessible Wifi router in order to connect to the Internet. The message means that there isn't one.
I can't connect my DSI to the internet because it always says i have an error code and my locks are gray and never unlocked so i need some help my worst problem is the error code.
Welcome to Fixya. If you want to connect your Dsi to the internet all you need to do is to follow my guide on the link below.
Nintendo DSi Connectivity Guide
Thanks for using Fixya.
5helpful
2answers
Error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
2answers
My wii keeps saying error code: 204969
Error Code: 204969 Nintendo DSi Shop Errors - Network ErrorThere was an issue with your connection to the Nintendo DSi Shop. Please try the following:
If you have verified that your Nintendo DSi or Nintendo DSi XL system's internet connection is working, then there could be a temporary issue with the Nintendo DSi Shop. Please wait awhile and your connection again.
If you have tried the above troubleshooting and are still receiving this error code, please call us 1-800-255-3700 so that we may assist you further.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=204969&system=DS&locale=en_US&action2.x=21&action2.y=33
How can I connect my dsi to the internet
It will then search for wifi signals. If it's protected, you obviously need the key. Anyway, choose one, put in the key and whatnot, and it will then attempt to connect. If it was successful, it will say so. If not, it will tell you and five you an error code. This means some security of the wifi you're trying to use prohibits you from using it. If you are admin for the wifi, you can input the error code in Nintendo.com to find out what to do to open the connection up to allow you. After that, you can access the DSi shop, the Internet after downloading the Browser, or use Internet in games
My nintendo dsi will not connect to the internet it says " unable to connect to the internet. Check your connection settings and access settings. For help, visit support.nintedo.com code error: ...
If you have already applied the solution suggested by Nintendo without success, consider upgrading the firmware in your wireless router. In some cases, devices other than the DSi connect with no problem but the DSi shows the error code 052201.
2answers
Nintendo dsi getting error code 52103 for usb connection
it seems like cant find the server , search teh error code form nintendo .com
10helpful
2answers
No internet dsi
nintendo .com tipe in that exact err code.tttttttttttttttttttaaaaaaaaaaaaaaaaddddddddddddddddaaaaaaaaaaaaaaaa
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
