Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Reset Default Settings
I have activated the progressive scan which made the screen go black I cannot see anything to activate default settings via a menu, is there a way to reset the console without using the menu say a button combination or the like. If you could please advise me to what the fix may be.
Mikel
  • Delirious76 Jul 17, 2008
    Thank you for you assistance - I did try that but it did not reset the system into factory settings - it only reset some settings. but I was able to blind navigate through the menus and have now managed to deactivate the progressive scan.
    Cheers
    Mikel
    Problem Solver:
  • 12 Answers
Hi
with the unit ON press and hold for at least 5 seconds the power button, you will see the clock goes to 12:00
This procedure will reset the unit to factory settings
Posted on Jul 17, 2008
How to open the gprs on nokia 5230
FOR GPRS YOU HAVE TO ASK YOU SERVICE PROVIDER.
JUST CALL ON CUSTOMER CARE AND ASK THEM TO ACTIVATE GPRS ON YOUR SIM CARD.
USUALLY NOW A DAY SIM CARD COMES WITH PRE ACTIVATED GPRS (0 RENTAL PLAN).
IF YOU HAVE ACTIVATED GPRS THEN AGAIN CALL CUSTOMER CARE FOR GPRS SETTINGS.
SETTING WILL DELIVERED TO VIA SMS. SAVE THEM AND SET THEM AS DEFAULT SETTING.
NOW OPEN YOUR DEFAULT BROWSER AND ENJOY.
ALWAYS USE FIXYA TO FIX YOUR PROBLEM.
Feb 22, 2011 | Nokia 5230 Cell Phone
I can't turn the video ouput on.
It may be a variety of things:
1. Make sure your TV is set to the right input for the cable you are using (Composite, Component, HDMI, etc.).
2. More often then not progressive scan may be set. If your TV is not compatible with progressive scan then you must try the following to turn it off:
  • Look for an external button or remote control button that turns progressive scan on or off.
  • Remove any discs from inside the DVD tray with the power on, then hold down the Stop button on the front of the DVD player for about 10 seconds to see if this will reset the system to default (i.e. no progressive scan).
  • If this does not work, you will need to contact the manufacturer for the exact reset steps for restoring to default settings.
3. Lastly, the video processor could be malfunctioning. This would mean a technical repair.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 15, 2011 | Apex Digital AD-2500 DVD Player
Blue screen with progressive scan mode displayed.how do i clear this its a zenith zhx313 dvd vcr combo
There are a few options here. If you have another TV that is "HDTV Ready" logo'd then you can hook this to the DVD player and go into the menu and remove the progressive scan setting then retry it on the original TV.
  1. Look for an external button or remote control button that turns progressive scan on or off.
  2. Remove any discs from inside the DVD tray with the power on, then hold down the Stop button on the front of the DVD player for about 10 seconds to see if this will reset the system to default.
  3. If no joy, you will need to contact the manufacturer for the exact reset steps for restoring to default settings.
Feb 01, 2011 | Zenith Televison & Video
The machine has been idle for two years due to office closure. I started it today and everything works fine except the touchpad which looks fine and switches from copy to scan to fax. Is there a way/need...
To default the priority display screen, perform the following:
1. Press Utility button.
2. Select Administrator Settings and enter passcode (default 12345678).
3. Select System Setting.
4. Reset Settings.
5. Select System Auto Reset.
Dec 18, 2010 | Konica Minolta bizhub C250 All-In-One...
I get a double black-and-white image when the TV is running through the VCR
I had this same problem once. Go on your dvd menu and go to settings and hit "reset default settings". That worked for me. Hope this helps.
Aug 31, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
After resetting to default settings, the shooting mode screen is black
Remove the batteries and put them back in. See if it restores the camera seettings.
Jul 19, 2008 | Canon PowerShot A95 Digital Camera
Possible to change default scan setting to PDF?
go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Jul 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Colour selection Scan settings
Set up the copier to the settings you wish to use. In the Utility menue there is an area called "Default Setting" (?) selecting this will give you the current settings as default, here you can also reset to factory defaults
Jan 08, 2008 | Konica Minolta bizhub C250 All-In-One...
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
