Question about Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Muted t.v. channels
My television has recently developed a problem. Some of my cable channels do not have any sound, yet others do. Also, some of the other channels have sound that is in another language, or not in synch with the picture. Like I said, this has not been a problem the entire time I've had the television, it's only developed recently. If you have a solution, I'd really appreciate it.
  • lildreamer05 Jul 09, 2008
    Thank you SOOO much!
  • Anonymous Mar 20, 2009
    have the same problem, did you get any answers?
  • 78 Answers
Hi lildreamer05,
Many stations broadcast seperate audio channels to allow commentary or alternate languages to be heard if desired. I recommend navigating your audio settings and looking for "SAP." If this is selected, turn it back to "Stereo," "Mono," or whatever other option is applicable to your audio setup.
Thank you,
Go Ahead. Use Us.
Posted on Jul 09, 2008
We have sound but no picture what to do
No sound
See the + - and thr triangle in between all on the same button press that button
Check if the sound is muted by pressing MUTE
Scroll to other channels there may be problems with broadcast.
Check if the audio cables are connected properly.
The scart connections are sensitive.
good luck
Feb 25, 2012 | LG 42LC2D 42 in. LCD HDTV
I have recently lost the sound on my 32 inch LCD tv
1.) Check its not muted/ the sound is all the way down
2.) If the TV has seperate speakers make sure they are plugged in to the main unit.
3.) If you are watching tv change the channels, if any channels have sound then the one you were watching has lost signal, try retuning.
4.) If all these have failed your TV may be on the way out :(
Mar 05, 2011 | Televison & Video
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
No sound on several channels.
switch the cable box from one tv to another one see if the box you changed works on the tv set you removed the cable box from on all channels if it does work after you swap out the box then it has to be bad!!!
May 12, 2010 | JVC AV-27530 27" TV
The sound won't work on my tv unless it is a dvd or vcr tape is playing or my video game system is playing. other than that I get no sound out of the tv at all
If you are using a cable box to recieve tv channels make sure that the sound is not muted on the box, usually you get a small icon indicating that the sound is muted. The other cause of the audio loss could be a problem in the sound processing circuit(IF circuit) you will need to take the set in for an estimation in that case, some troubleshooting will be required. If you are using a cable box one thing you can do is to run some dubbing cables from the a/v jacks in the located in the rear and connect them to one of the tv ext. inputs(like you are connecting your dvd,vcr) this should give you audio when viewing your tv channels. please leave good feedback if i answered your question satisfactorily.thanks
Aug 26, 2009 | Televison & Video
Sound on 2 channels a problem
I diconnected a recently acquired Panasonic DVR which was hooked up between my TV and the cable signal source, but this had no immediate effect on the two channels. I then reset the TV by unplugging it over night, and by changing the settings on the sound menu. These actions removed the problem. Is it possible that the DVR caused the problem?
Dec 08, 2008 | Digimate DGL32 32 in. LCD Television
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No sound on random channels
it sounds like you have SAP enabled. Refer to your manual or on screen menu to verify that it is disabled.
Dec 07, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Memorex MVDT2402 24 in. TV/VCR/DVD Combo Logo
130 people viewed this question
Top Memorex Televison & Video Experts
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
