Equalizer hookup I have a equalizer and a home receiver and I would like to know how to connect them the right way, can you help me?
  • zomba3 Aug 01, 2008
    hello, how do I hook up my eq to my recevier? thanks
  • 682 Answers
General rule of equalizer connection as following:-.
preamp out-------equalizer---------amplifier---------------loudspeaker.
Posted on Jul 12, 2008
Need manual
Ron there is no such manual except those that might come with the Equalizer- Actually , the process is very simple. You take the output of the equalizer in hook to tape in. Tale the record out of the tape loop and hook to input of the equalizer. Then the equalizer will work when the tape look (tape monitor) for the receiver is selected- that is why it is called a tape loop as signal goes out and comes back in. If you have Pre outs and Pre in you could use it there too. In the tape loop connection any tape deck is then hooked to the Equalizer tape inputs- some have two.
Dec 31, 2012 | Audio Players & Recorders
Hookup
It would help to know what equalizer you have, but I will assume it is a stereo analog unit. With the exception of the Tape In/Out connections on the back of the receiver there is really no provision for an equalizer. Even the Tape I/O connections are of little use if you can't monitor the source through the Tape In connections. Even if that were to work, it will not function for any digital sources you may have. You should be able to install this between an analog external source and the input to the receiver if you have one particular device you would like to tweak.
There are equalizer settings you can control within the receiver itself. You have the option of selecting the manual method for equalizer settings for each speaker or the default automatic method. Granted there are only 5 frequencies (3 for the sub) that you can adjust, but the fact that you can adjust each speaker separately is an advantage. The following was taken from the owner's manual:
• The front, center, surround, and surround back speakers
can be adjusted at 80 Hz, 250 Hz, 800 Hz,
2500 Hz, and 8000 Hz. The subwoofer can be adjusted
at 40 Hz, 80 Hz, and 160 Hz.
• While the Direct or Pure Audio listening mode is
selected, the equalizer settings have no effect.
• This procedure can also be performed on the AV
receiver by using its [SETUP], [ENTER], and arrow
buttons.
This is a very good receiver with some great features. If you have performed the Automatic Speaker Setup, you can go to the equalizer setting and select Off, Audyssey (automatic) or Manual.
Hope this helps.
Oct 15, 2008 | Onkyo HTR500 Receiver
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Yamaha 5.1 receiverhookup to teac equalizer
record output from receiver to linein of eq,and line out from EQ to PLAYBACK of receiver Thank you very much albie 20
Sep 29, 2008 | Teac EQA-120 Home Equalizer
Hook up to Ritron EQ
record out-------equalizer in---------equalizer out-------playback in.
Sep 04, 2008 | Spectrum Technical Hifi EQ-B5100...
Equalizer hookup
record out from receiver to line in in equalizer and line out from equalizer to playback in receiver-------but you have to check the result by yourself and watch if it is better than befor or not,
Aug 17, 2008 | Audio Players & Recorders
Conecting my EQ to my Yamaha reciever
your media out(dvd-cd-dat-deck player)-to equalizer in-and equalizer out to aux or cd in receiver.
Jul 17, 2008 | Yamaha EQ-70 Home Equalizer
media out(dvd-cd) to equalizer in ------equalizer out-------to aux in or line in in receiver.
May 25, 2008 | DBX 1215V Home Equalizer
Connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Dec 27, 2007 | Audio Players & Recorders
568 people viewed this question
 Grubhead
Grubhead
