I havea hp dx2000 lap and my screen was giving off some really bright colors and the screen finally went out so they replace a switch this time I have had this computer looked at 4 different time even by hp and every time they tell me it is something different and they fixed it but yet when I get it back I still have these really bright floresent color showing up bright oranges or reds or mixed pink and blue no one has ever fix this problem they say it fixed but when I get it back it is the same
  • 71 Answers
It could be screen inverter or graphics, it has on bored graphics is it could mean changing the motherbord
Posted on Jul 06, 2008
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
Dash lights do not work 2000 ford exploier
All go out at once, first check fuses,then dimmer switch for dash lights, finally headlight switch. To check dimmer switch, pull connection off back, on harness with test light and headlight switch activated, 1 of the leads should have power, if so, use ohm meter on dimmer to make sure it has reading between 0 and some value, if no value, open, dimmer is bad, if there wasn't power then check headlight switch, there should be heavier gauge wire that powers switch and 1 for output to hi/lo switch, smaller gauge wires for tail lamps, dash lights, license plate lamps, parking lights. The color wires from dimmer would correspond to the same colored wires on headlamp switch, probe that connection on headlamp switch with switch engaged and see if you have power, if not replace switch, if so, check wire from switch to dimmer.Now if the lights slowly went from bright one day, to less bright some other day, to not working, then the bulbs are bad... good luck...
May 14, 2012 | Cars & Trucks
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
Princeton 19" went from bright white to dull white
david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
Screen Brightness is set too high. Washed out.What Buttons do I push on an HP Pavillion lap top Model N3295 ?
Go into display settings and click on advanced settings, then click on the color tab. There is a slider in there that controls the screen brightness. This is for windows xp but vista should be similar.
Mar 09, 2010 | HP Computers & Internet
Laptop monitor comes on bright whitish color
may be the LCD display of the laptopisgone or ur VGA adapter has some issues
Jul 26, 2009 | HP Compaq Presario C700T Notebook
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Possible convergence problem
You could replace it yourself. I had it done recently and the local repair shop charge $400 to do it (including cost of the chip).
Jan 30, 2008 | Toshiba TP50H50 50" Rear Projection...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
