Ntkrnlpa.exe issue I am trying to do fresh windows xp install on IBM think Center A30. Machine type is A1U 8198. 2.8 Ghz processor, 1GB RAM . I took out the original non SCSI Hard drive because it look like it died. I replaced it with SCSI IBM Ultrastar model DDYS-T18350 hard drive and I am having hard time installing any operating system on it. I tried, Xp, Windows 2000 Advanced server, Windows NT. Every time I get the error " set up can not copy the file ntkrnlpa.exe" I took out SCSI hard drive and tried doing fresh install on the original hard drive after reformatting, still the same error. Any idea what could be the reason? Couple of weeks ago system had been running normal on the same machine with original non scsi hard drive but then computer started freezing more often. At hat point I thought of changing the hard drive.
  • 8,617 Answers
Sorry, wish i could help you out, however i dont have any experience with computers what so ever, try resubmitting your request to one of the other experts i am sure one of them will be able to help you.
Posted on Jul 06, 2008
I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
Otherwise, your operating system or hardware problem will occur.
Dec 29, 2010 | Microsoft Computers & Internet
Can i386 unidrv.hlp for xp pro sp 3 be downloaded from Microsoft?
  1. Insert the Windows XP startup disk in the floppy disk drive, or insert the Windows XP CD in the CD drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD drive if you are prompted to do this.
  3. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  4. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  5. When you are prompted, type the Administrator password. If the Administrator password is blank, press ENTER.
  6. At the Recovery Console command prompt, type the following lines. Press ENTER after each line. cd system32
    ren ntkrnlpa.exe ntkrnlpa.old
    ren ntoskrnl.exe ntoskrnl.old
    cd "c:\windows\driver cache\i386"
    expand sp2.cab -F:ntkrpamp.exe c:\windows\system32
    expand sp2.cab -F:ntkrnlmp.exe c:\windows\system32
    cd c:\windows\system32
    ren ntkrpamp.exe ntkrnlpa.exe
    ren ntkrnlmp.exe ntoskrnl.exe
  7. Type exit to quit Recovery Console. Your computer will restart.
Or go to http://www.ventrilo.com/dlprod.php?id=1 and click on agree.
Nov 03, 2010 | Epson Stylus Photo EX InkJet Printer
Can not load drivers do not have disks tried to down load from the net.
Maybe you're using a wrong set of drivers. Try to distinguish your operating system first to install the right set of drivers.
For example in Windows XP 32Bit is differ from Windows XP 64Bit Set of Drivers.
View System Information
  1. Click Start, and then click Run.
  2. Type winmsd.exe, and then click OK.
  3. When System Summary is selected in the navigation pane, locate Processor under Item in the details pane. Note the value.
* If the value that corresponds to Processor starts with x86, the computer is running a 32-bit version of Windows.
* If the value that corresponds to Processor starts with ia64 or AMD64, the computer is running a 64-bit version of Windows.
Feb 17, 2010 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
I have pentinum4 intel(R) celeron processor 1.3 GHZ processor. I want to increase the speed of my processor without any hardware change. I have 40 GB HD & 512MB with windows XP RAM.plz help
you cannot change the speed of your processor unless your processor supports overclocking. however your processor does not support that.
if your computer is running slow try upgrading the RAM to 1GB.
also check to see whether you have unwanted applications running in the background
Jan 25, 2010 | Intel Celeron D 335, 2.8 GHz Processor
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
Nov 05, 2009 | Samsung X05 Notebook
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
Home Premium / Business / Ultimate
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Jul 11, 2009 | Microsoft Windows XP Professional
Loading Vista
for getting windows vista installed on the machine you should have the configuration of 1gb ram , 1 ghz of processor and 100 gb of hard drive if that is there then you must get it installed without any issues . If this is not the configuration then you should have this configuration first and then get it installed
Mar 31, 2009 | Computers & Internet
Slow laptop dv 9208 w vista
If you're having Vista, you will need 1gb RAM minimum. Vista is resource intensive, concentrated more on graphics, and a lot of Hardware compatibility issues. Windows XP is fine and better as of now which runs great with 1GB of ram and a pretty processor of 2.0 ghz ...If you think of speeding up ur lappy better go for XP .increasing ur RAM will increase the number of apps that you can run productively at a time.
Mar 28, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
