Question about Tower Aloha Breeze Fan
Aloha breeze industrial floor fan
My aloha breeze industirial floor fan is overheating at the motor part, and making a loud squealing noise sometimes-it has a 25 year warranty, and it is not even a year old yet, could this be a problem with the motor? Could there be dust in the motor? Does aloha breeze has a website? I can't find it. Any suggestions?
ty - Misty
  • 2 more comments
  • DEVARIO2008 Jul 06, 2008
    I HAVE JUST BOUGHT THE FAN  A MONTH AGO,AND IT STARTS SLOWING DOWN WHILE IT SPEND AND GOES REAL SLOW,AND THEN IT CUTS OFF AND STOPS WORKING.CXAN ANYONE HELP ME
  • rallen650 Aug 27, 2008
    Our Aloha Breeze 20" High Velocity is having a similar problem. Sometimes is will start up....sometimes it won't.....it just hums. Fan is less than a year old and hasn't been used hardly at all.
  • banditrapper Nov 14, 2008
    i have a squeking and some times it starts and run sometime it hums and now it smoked out of the motor . i only bought it in may 08
  • Deb Kwek Aug 23, 2013
    I have 2 Aloha breeze 20" high velocity floor fans ans both are only a year old and stop working the number on the manual does not work to get in contact with the company?? what a waist of money!
  • 9 Answers
I assume this is the very popular 18-inch High Velocity sold at Wal-Mart. If you cannot return it to your local store contact Aloha Housewares at: 1-800-295-4448. Good Luck!
Posted on Jul 09, 2008
  • grotemuis Aug 15, 2011
    This phone number does not work.
    I think "aloha" ran off into the island-sunset and is fanning them self with ocean breeze ( because their "breeze" fans are worthless).
    I bought 2 Aloha Breeze 20" high velocity floor fan after aone summer of use they both died and do not work? call the number on the manual that number is non working?? what a waist of money!
Go buy a new one from walmart, clean up the old one and return it a couple days later and get your money back. Walmart sends it back to the factory as faulty merchendise. Figure if they are going to make them shoddy serves them right.
Posted on Sep 05, 2008
    I am planing on doing that I will never buy from this company again!
I have the same problem with mine so I tore it apart to see why. It appears that instead of using a bearing where the shaft mates to the inside of the motor they just have the shaft going into a pocket of sorts. The surface area that makes contact must have a very smooth finish. Hence a bearing...if it wears out then you just replace the bearing.I do not think it is a good way to put them together because you need grease for everything to turn smooth and there is a complete lack of grease. I am going to regrease it and see if that solves the problem for now but I will not buy another one of these fans as I can see this as being an on going problem. When the grease is gone you have metal rubbing on metal causing the motor to over work it self and the shaft or where it rests will wear out causing permanent damage. I am hoping there is no permanent damage on mine. I see some wear lines but it does not appear to be anything significant. I will let you know what the conclusion is after I get into town to buy some grease.
Posted on Sep 01, 2008
    wjones4 did that ever help??
Very nice fan, but internal bushings move around and shaft binds on rear mounting pocket. This causes the fan shaft to bind. I found I could get less drag when the shaft was pulled out toward the front. Went got a 1/2" of pex tubing and 3 washers. Took the motor apart put a washer on the shaft where the shaft pockets into the rear motor housing and oiled. Put motor back to together. Loosened the blade hex screw and pulled the blades off. Gave the shaft a gentle tug forward, put on a washer, slipped the pex tubing (acts like giant bushing and keeps the fan shaft in a low drag posture), put the 3rd washer on, then reattach the blades. Lubed everything with 3 in 1 oil. If this thing had wings, it woud take flight.
Posted on Jun 27, 2010
The manual says that the motor is self contained and permanently lubricated. That's a lie. I'm on my second one. The first one gave out inside a month (overheating and squeaking then finally wouldn't run at all). I took it back and got this one. After about 6 months (this is the second season of running it) it started squeaking as well and the rpm's started dropping (I've got perfect pitch so could tell by the pitch of the motor). I said to hell with it, took the front cover in the garage and shot a couple of drops of 30-weight motor oil into the motor where the shaft comes out that the fan blades attach to (do NOT put the oil anywhere else!!! ONLY THROUGH THE MIDDLE SHAFT), made sure that it got down inside the "axle", brought it back inside and it's running like new right now.
When it starts heating up/slowing down/squeaking just oil it. I'm gonna get a can of 3-in-one oil just for this purpose. I know it's a drag, but otherwise it's a kickass fan!
Posted on May 26, 2010
I dont know if i have the same model fan but, i finally figured out this thing. play with the MODE button and you will see that it works in different ways. has a timer and swinger and remote too. Instead of blowing constantly on you, it varies it's air flow. it's cool actually.
my problem is i got it from someone without a manual and i think it my need oil or grease because it makes alot of noise sometimes.
Posted on Oct 10, 2008
Where can i get motor for Aloha Breeze Floor Fan Model 12001
online search or hvac / parts stores like granger , etc ==take the nombers off motor the get a match
Jul 08, 2017 | Dryers
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Aloha Breeze 16" Vintage Stand Fan Model #46051 (46052) Serial #03156: Trying to open up the case to get to the motor, to try and replace a fuse or something that's making the fan not work. I got the...
It isn't worth fixing. I am on my second one which didn't last any longer than the first which was about 3-4 months. These fan motors are junk. First failure was a bearing and when it started failing, it was noisy. Eventually, the fan would not start because the motor didn't have enough torque to overcome the friction in the bad bearing.
The second fan was quiet but has NO starting torque....no unusual for fans generally, but I'll NEVER BUY another ALOHA BREEZE product again.
Sep 08, 2010 | Tower Aloha Breeze Fan
Fan making humming noise and wont turn
The fan motor cannot turn because either the bearings are dry and turning hard or the motor has worn out...You can try to take it apart and lub the bearing with WD-40 and a light oil... it may work.
heatman101
Apr 19, 2010 | Tower Aloha Breeze Fan
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
When engine fan engages makes loud squealing noise
Either tighten the fan/drive belt or replace it .. it is loose ...
Mar 22, 2009 | 2000 Mazda MPV
Tower Aloha Breeze Fan Logo
2,825 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
