Question about Dell Inspiron 1000 Notebook
Power supply you were able to replace the ac power unit? was it fairly easy to do? any advanced technical knowledge needed? my dad gave my his old inspiron and i have another dell with a broken ac plug and if it was cost effective i would like to repair both unit and turn them into linux units
    Genius:
  • 2,028 Answers
I believe you're talking about the DC jack on the computer, if so, then you can find one on Ebay at a very cheap price, around $3. To install this you will need to disassemble the machine down to the motherboard. The jack is soldiered to the board. Once you get the board out you will be able to see the soldiered connections. You'll need a soldiering iron and soldier, remove the old and resoldier the new. Here's a couple of links with breakdown diagrams for various machines, you may be able to find one for your machine.
http://fileshare.eshop.bg/index.php?what=search2
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
http://repair4laptop.org/notebook.html
Posted on Jul 07, 2008
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
How to connect a cassette deck directly to the AC power
First you need to find out what voltage etc that came along the wires. Try finding the service manual for the model. Then all you need do is get/build a power supply. There are various ones on the market (AC Adaptors) for phones etc. Just get one that matches the supply. You may have to fit a plug of somekind into the deck. The supply might have to be smoothed by a capacitor say 2200uf. If it does build a small circuit board and fit it inside the deck. The voltage of the capacitor will have to be greater than the supply voltage of the adapter (IE:12 volts = 25volts cap).
Jan 04, 2010 | Audio Players & Recorders
No power to the vcr
Probably not just a fuse but it is related to the power supply, which in newer VCRs is likely a switched mode supply but linear in older ones. Either one is a fairly cheap and easy fix for a competent and honest tech.
It is safe for you to open the unit and look for a fuse, most often located close to where the AC line comes in. However, some units may have the fuse soldered in rather than in a mounting clip that is easy to access for replacement. If you find the designation 'F1' near a soldered component, a soldering iron and some disassembly will be needed.
If a replacement fuse blows, it is fruitless to replace it again; you will require a technician then as that would indicate a failed semiconductor in the supply.
Nov 29, 2009 | Mitsubishi Televison & Video
Technics SL-QL15 turntable for the charity shop?
If it still in perfect running condition, An audiophile of LPs should be interested in buying it. I sold my 30 year old Technics SL-1300 mkII for $250
Jul 30, 2009 | Audio Players & Recorders
My HP Pavilion computer unit will not turn on. Have tried unplugging, replugging; all the cords/plugs look good. Unit is quite old (at least 10 years). Monitor still seems to work. Is it dead?
Could simply be your power supply. Please check that the power cord is connected to the computer and that the power supply switch (located in the back next to where the power cord plugs into the computer) is in the on position( I = on 0= off). IF the power cord is plugged into a working outlet and the power supply is on then it can only be one of two things. You have a bad power supply( easy fix that will only cost you about $50 or less) or your motherboard is bad. If you took this into a shop for repair they would pull out the power supply and replace it with a know working one. If that does not fix the problem then they would tell you your motherboard is bad. Power supplies are fairly easy to replace and, for your unit, very cheap, about $15 from newegg.
Jul 20, 2009 | HP Hewlett Packard Pavilion Slimline...
Clicks on but screen stays black and then it shuts off
With fair certainty, this is a problem with the main power supply. If no longer under warranty, pull the AC plug overnight to allow stored voltages to discharge before opening the set.
The power supply board is normally separate, visibly related to the AC coming in and has larger parts such as capacitors (cylindrical cases) and block-shaped parts (chokes and transformers). You can probably replace this board yourself but you need to call Sanyo/Vizon to learn whether you can get yours repaired or if you must buy a new one. If you have to buy one, don't toss the failed board since there are independent companies that can repair them for a few dollars less than the cost of a new one. It doesn't hurt to have a spare, these aren't your dad's TVs and are not lasting as long as our previous sets.
Jul 15, 2009 | Sanyo Vizon LCD-15A2 Television
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
Gateway Power Supply
It's not likley the power usage that did in the power supply unless you split the feeds numerous times. The switch should be straightforward, unplug all the feeds paying attention to what you unplug and only unplug what comes from the power supply. It should be a simple matter then to unscrew the supply from the case, remove the old and reverse the operation.
Jan 01, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
Dell Inspiron 1000 Notebook Logo
63 people viewed this question
Alun Cox
