Question about Refrigerators
Our Subzero 561 ( -15 yrs. old) just started making a rattling noise. It sounds like a fan is hitting ice. It stops when we open the freezer door. When we look up in there, ice is caked on. What steps should we take?
  • Anonymous Nov 30, 2008
    Exact same noise and problem on my 561. My Sub zero is 15 yrs old too. Pretty coincidental! I bet thats simply the life of the fan or thermometer? How do i figure out which one of the three possible problems it is without calling an expensive service repair person to come out?
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
When freezer drawer is closed, very noisy. Noise stops when you open freezer door. Is is the fan?
It sure sounds like the fan is either just going bad or there is possibly is hitting the blades. if it is a buzzing sound then ice is probably the problem. if it is a rattle or squeal then the motor is bad.
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Ge profile psc23pswa rattling noise
You have actually defined the problem. It is the fan and they normally turn off when the door is opened. Check the fan and be sure the blades can rotate freely. Normally if you fake out the door switch the light will go out and the fan will start.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frig is driving me crazy---weird noise and no ice!!
That might be the fan. Making that noise, because fan stops when you open the freezer. The ice maker might be a totally diffrent problem. The solenoid may not be opening to let the water in, which is usually cause by a bad solenoid.
Nov 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
