Question about Kitchen Ranges
Heat is escaping from my westinghouse oven because the rubber tape that fits the door is broken (due to extended use). It was bought 13 years ago. Where can I find this appliance ?
  • burzerko
    burzerko May 11, 2010
    I will need a model number to find this part for you.
    Champion:
  • 254 Answers
I dont have your s/n or model number but try this link to find your door gasket.
Hope this helps Ya
please rate me
Posted on Jul 20, 2008
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
Very warm heat escaping from oven door
Hi dont know if you have solved this but our cooker was doing something similar.on one side and the dorr seal was fine. I turned off the mains, took the side panel off and it turned out the insulation inside had slipped down. I bought some more from eBay.co.uk and replaced all of the old stuff and now I have no problem....1 year on. Hope this helps
Feb 06, 2014 | Zanussi Ovens
Our TV/DVD player (LTV-32w4 HDC) is just out of the 4 year extended warranty we bought. The TV works fine, but the DVD player will not start up. When a disc is inserted, it seems to be trying to start...
Hello
According to your complaint post, the fult is due to its DVD mechanism itself. It will be best to replace the DVD tray mechanism [ plastic made one]. You can bought it from most of the electronic spare part shops at your town. But the model fitted with Westinghouse will be very difficult to get. Anyway try to get it. The fault is with loading tray mechanism itself. OK.
Aug 23, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
Oven door does not seal
Drill out the rivets with a power drill use nuts bolts and lockwashers where the rivets were Once the door is back on:
loosen all the door screws then bend the door diagonaly slightly to square it with the oven opening (don't worry you won't damage it) then tighten the door screws again check to see that the door is flush (no gaps)
May 21, 2009 | Heartland 3525SS Dual Fuel (Electric and...
GE JVM1640 won't heat
These microwave ovens have a series of door switches. One of yours has gone bad or a plastic finger on your door mechanism that pushes the switches is worn or broken off. They are commonly called NC or NO swithes some ovens have up to 6 of these working together.If you have no expertise in this field consult a repair shop. Please rate me
Comment posted on Jan 12, 2009 there are two types ,normally open and normally closed, NO NC . u have to check continuity on each one and each switch will have a diagram on the side showing its in use position. I hope this has been helpful
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
No heat
COINCIDENCE? Yes... :) So go buy another one, it'd probably be cheaper than getting the bad one repaired.
Geno
Feb 25, 2008 | Maytag MMV4205 Microwave Oven
Westinghouse Wall oven mod.PON 667S
Hi there.
Westinghouse have produced a modification which replaces the left and right door support channels in the front of the oven.
Call Ryan Nielson Spare Manager at Axial Appliance Servicing www.axial.co.nz
in Mt Wellington Auckland, and he can sell you the reinforced parts which cost me $27 for my oven.
I am replacing these channels myself this weekend as warranty no longer applies to our oven, but if yours is still under warranty I'd suggest that Axial will do the whole job.
Dec 16, 2007 | Ovens
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
