I just bought this as a gift for my husband on our anniversary. The day I bring it home the belt falls off and as we desperately try many ways to get it back on...the turn table spinner doesn't turn now! I just got this today off a private owner who wasn't much help. I wanted a gift not a project so if you have any suggestions on how to get this up and running it would be more than appreciated!!
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it...
(More)
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
Everything works except the CD player won't engage most of the time. When it does it then skips like...
(More)
Everything works except the CD player won't engage most of the time. When it does it then skips like the CD is scratched even when it isn't. Are ther replacement CD players for the units or is there an easy fix? Ivan
My turntable works fine and the cassette player also. The CD player sticks and will not pop out I...
(More)
My turntable works fine and the cassette player also. The CD player sticks and will not pop out I have not used the unit that much for it to be malfunctioning so soon. can you recommend something
Our unit is about 8 years old. The primary problem is with the cd player. The door comes out but...
(More)
Our unit is about 8 years old. The primary problem is with the cd player. The door comes out but often pull back in entirely. Even when it does go back in the "track" window says "E" (error). Suggestions from anyone?
