Question about Dryers
Fitting new drum belt to Simpson Dryer
Can someone advise how the belt around the drum loops around the motor?
Thanks
Andrew
  • Anonymous Mar 14, 2014
    dryer motor comes on but drum isn't spinning
  • 481 Answers
It all depends on the brand of the dryer. go here for diagrams for a bunch of brands.
http://www.repairclinic.com/0079.asp
Posted on Jul 06, 2008
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Dec 18, 2009 | Dryers
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
Reassemble dryer
to replace and go back together you need 1st put in the drum with the felt at the back, slide belt around drum, hook the idler into the **** on bottom by motor, pull idler back, loop belt though idler and over motor pulley ,,,,, it takes time if never did it before but can be done in about 10 minutes.
Larry
Nov 24, 2008 | Kenmore 62602 Electric Dryer
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
1,091 people viewed this question
Top Dryers Experts
