Compaq Presario CQ60-220US PC Laptop Logo
michael bunkem Posted on Dec 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer is in one stage telling me the application is missing or corrupt, it stays on that one screen, i need help to reboot it to factory settings
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Dec 26, 2010
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785186
Points
9440
Hello.
Reboot your computer and during the first part of start up repeatedly press the F11 key. This will successfully restore your all settings.
Hope this helps.
Im trying to reboot with out os cd im in the bios boot mode there is a ! mark next to network adaptor
Your network adapter's driver may be missing or corrupt.
Did you do a restart or a reset ?
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
My certified data laptop quit all of a sudden and turning it off and on or even removing the battery does not help it just goes to safe mode or open windows normal and the screen stays blank
Symptoms seem to indicate either corrupted or missing driver files (probably other corrupted files on hard drive as well).
You can boot into Safe Mode, then run Command Prompt, and type the following to try to correct corruption on the hard drive:
chkdsk c: /r
You will get a message telling you the drive is in use, and would you like to run on next restart. Type "Y" and hit enter, then restart the computer. Depending on the size of your hard drive, this could take hours to run, but be patient.
If this does not resolve your problem, the next thing to try is (in Command Prompt again) "sfc /scannow". You will need your installation disks as this program does a full System File Check and will ask for your installer CD/DVD to replace any missing or corrupt System files it finds.
I hope this helps...
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
1helpful
My laptop is saying i need to insert windows installation disc and restart comp file windows /system32/winload.exe status oxcoooooof info this selected entry could not be loaded because the application...
your boot record is corrupt..
get the recovery disk or install disc
then reboot and boot the install disc
the first screen has a "repair startup" option
goto there... it is all then obvious
I just receiver recovery and system disc from Acer to restore my laptop to factory settings. I tried couple times and followed the instructions. The recovery disc formatted partition 2 on the computer but...
Looks like your recovery cd is corrupted. You must obtain a copy of Ms Windows cd and install it using the license from the back of your laptop.If that doesn't work either its a hardware related (hdd) problem.
Black screen on monitor
this will be the onboard VGA adaptor ( driver Missing Corrupt ) there are a couple of things to Try.
1:- remove power from Computer, Locate the Cmos battery ( small round battery that stores Bios Info ) remove battery for 10 seconds. replace. power up and boot.
2:- If your computer has an onboard graphics card Slot. AGP/Pci-express. add an additional card, and attempt to run on that card. to boot the computer, enabling you to re-install the corrupt/missing vga driver.
thankyou for using fixya.
Mike @ Compurepair.
1helpful
2answers
My computer is telling me that the nltdr is missing
Read this link if you like
http://www.techimo.com/forum/applications-operating-systems/136282-fix-ntldr-missing-xp-works-2000-well.html
Goodluck
<windows root>\system32\hal.dll is corrupt or missing
See if you can get into safe mode. If you can't then your system files are corrupted and you'll have to restore your computer back to factory defaults.
I believe on your compaq presario they have a built in factory restore and its either accessed by the F10 or F11 key when you first turn on the computer. You'll know when you first turn on the computer at the compaq logo screen.
Let me know if I can help you further.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
