Question about Philco (R) Classic Turntable CD Shelf System
BELT FALLS OFF
Hello Dan,
I just purchased this item from someone local who told me sometimes the belt falls off and you can easily pop it back on. Yeah Right! I bought this gift for my husband's one year anniversary and we have spent more time trying to repair it than listen to the albums! And to add to that, now the table doesn't even spin! Since you live in the same state we do (MA), I was wondering if you could offer any help...I really wanted a gift for my husband to enjoy--not a frustrating project! Any insight on how these players work (or fix!) would be greatly appreciated.
Thanks,
New Broken Owners :(
  • 4,234 Answers
Without the model number, I can't supply the belt number or size. These belts do stretch over time. If we can find the correct one, the belt shouldn't be more than $8-$10. If you aren't far from Lancaster, there is a flea market there that has a repair booth. You can try there as well.
Dan
Posted on Jul 06, 2008
Why doesnt my dryer start? drum doesn't turn
most direct reason would be belt popped. once the belt pops the wheel and arm it wraps around falls down releasing pressure from a push switch that allows the dryer to start.
May 18, 2014 | Samsung Dryers
What items are to be removed to replace timing belt. are there any pit falls?
if belt broke u need to find out if engine interferace fit.where belt purchased can tell u.if yes could bend valves.if just replacing mark gears to block with felt pen.roll engine over couple times and recheck,before reasembaly.
Feb 11, 2011 | Kia Sorento Cars & Trucks
Drive belt problem
You can go to a local electronic store with your belt.
He has a replacement which is smaller.
Don't buy the original (expensive) belt.
Regards,
Gerard
Feb 01, 2010 | Technics SL-MC50 CD Player
My gold star microwave worked lastnight. Went to
The outside bottom of your microwave usually has a belt hidden underneath a small cover directly under the turntable. This belt sometimes falls off or breaks, and sometimes the motor that turns the belt fails. Most time the motor can be found if you remove the main top cover of the microwave, about 10 screws.
Parts can be easily found at your local appliance parts store.
Best of luck.
Jan 20, 2010 | Goldstar Microwave Ovens
Drive belt falls off mower
You need to inspect the pullies holding the belt, and the bearings that run the pullies. If they are bad they will jump the belt.
Oct 29, 2009 | Garden
Whirlpool cabrio dryer belt falls off after install
If you're turning the drum backwards the belt will fall off. Make sure you're turning the same direction the motor will spin it.
Aug 11, 2009 | Amana NDE5800AY Electric Dryer
The belt on my hoover will not stay on. It falls
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
Jul 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
MY SONY LBT-LX90AV CASSETT PLAYS DISCORD AND BELT FALLS OFF
Hi. Make sure the flywheel turns freely and that the capstan pin and pressure roller are clean. If this is OK then it is more than likely that the belt is stretched, dried out or generally worn. These parts only have a certain usable life and are quite cheap to replace.
Dec 23, 2008 | Sony LBT-LX90AV CD Shelf System
BELT FALLS OFF
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Jul 06, 2008 | Philco (R) Classic Turntable CD Shelf...
Philco (R) Classic Turntable CD Shelf System Logo
87 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
