Question about Toshiba 62HM95 62" HDTV
Television Problem My name is Shane Burns.  I have a 62 inch Toshiba DLP rear projection high definition television.  It was bought in '06.  The television is now turning itself off and on non-stop; also I have no picture.  Is it a bad switch, bad bulb, etc?
  • allmansfan Aug 23, 2008
    I was wathcing television and the same thing happened. I bought a new lightbulb for $200 and it still would happen. Now I have a green light blinking and according to the instruction manual it is abnormal operation of the BUS line, and I don;t know what that is
    ANy help is appreciated allmansfan@metrocast.net
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
Posted on Jul 21, 2008
Sounds like a lamp (bulb). look at the front for red & green blinking lights and then the booklet that came with the tv for "troubleshooting".
Posted on Aug 24, 2008
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Toshiba model 62MX196 t.v. 62 inch rear projection...turns on then goes black and mute after 5 secs then red led continually blinks. Unplugging and rebooting power button causes a voice to say "fan st
I'M ASSUMING THIS IS A DLP? IF SO "ANY"
I REPEAT IF ANY OF THE FANS ARE SEIZED OR DRAGGING
SLOWER THAN THEY ARE SUPPOSED TO
IT WILL SHUT DOWN THE Tv!!!!! EVERYTIME AND THAT GOES FOR ALL OTHER DLP/LCD PROJECTION AS WELL!
BY DESIGN THEY DEPEND ON THOSE FANS, WITHOUT THEM THEY WILL BURN UP THE PARTS THAT THEY ARE ASSIGNED TO COOL. THE 3rd WIRE ON THE FAN PLUG SENDS A PULSE EVERYTIME THE FAN COMPLETES A 360 degree REVOLUTION, TO A CIRCUIT THAT MONITORS IT.
Nov 15, 2013 | Toshiba 46H84 46" Rear Projection...
No picture, has sound
HAD ONE ALMOST LIKE IT 62 INCH DLP LIGHT ENGINE DRIVE WENT OUT THEY DO NOT MANUFACTER IT ANY MORE WARRENTY COMPANY FEED ME A 60 INCH MITSUBISHI THERE IS NO HELP WHEN THE LIGHTENGINE DRIVE GOES OUT CASH IT IN!?
Aug 30, 2011 | Toshiba 57H82 57" Rear Projection...
I have a 62" DLP
Replace the lamp, model # is TB25-LMP. Good luck
Jul 24, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
Jan 04, 2011 | Toshiba 62HMX95 62" HDTV
My 62 inch Toshiba DLP keeps getting the timer rec error. I even bought a brand new bulb for it, what can it be?
have you reset the lamp timer I think that is all you need to do
here is the link
http://www.ehow.co.uk/how_7259862_reset-toshiba-dlp-lamp-meters.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE!!!
Oct 18, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 62HM95 62" HDTV Logo
397 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
