Question about Singer 7462 Mechanical Sewing Machine
Where can i find a parts breakdown on a 4562 singer sewing machine. I loaned it out and when returned the machine jams up. When i took the bobbin out the bobbin casing broken. The manual is lost. Please help if you can.
  • Farhat Kalsoom
    Farhat Kalsoom Feb 04, 2013
    At sell by v good seller. i bought 4 5 items there at good price.
  • 4 Answers
I bought my parts @amazon.comor order direct
Posted on Feb 04, 2013
Called a local service tech.
Posted on Jul 07, 2008
I am having a difficult time finding pressure feet for my Singer 4562 such as button hole, button sewing, embroidery, walking foot, quilting foot, etc.
You should be able to find presser feet for your machine as long as you know what type of shank your machine takes. Just confirm that whatever you choose will fit a Singer model 4562. You can even purchase a snap-on shank adapter and then purchase snap-on feet for your machine.
Product Quick Search 318 335 4567
Sewing Parts Online Search (look for 4562)
Apr 23, 2016 | Singer Sewing Machines
I have a Singer 4562 T sewing machine. When I try to sew the bobbin case is jumping out of the housing. With the slide closed I sew until everything gets a mess on the underside. When opening the housing...
pl open the entire bobbin housing two scrwes with suitable screw driver and clean .test the latch on the bobbin case,look for steel tension strip screw replace the unit ,also replace needle
Dec 11, 2013 | Singer 7442 Mechanical Sewing Machine
Singer 4562
here is a link for a free manual, then information of how to insert the bobbin case into the machine
Sep 08, 2013 | Sewing Machines
Hi there in this long link you will find instructions for your Singer, I hope the bobbin will not give you any trouble after having read all about it.
Mar 17, 2012 | Singer Sewing Machines
I have a singer 4562 and the bobbin case is broken and does not hold the bobbin in. Can I fix it? If so how can I fix it?
Once those break they are a pain to fix. Your easiest bet is to buy a new one. Here's a link for the type you need
Or you can get one locally, its called a "Singer Apollo bobbin case". Also don't forget to add a drop of oil at the meeting of the bobbin case and the outer hook (silver circular part that picks up the thread)
When they break, it leaves a bur sometimes and it will cause thread breakage/jamming.
Let me know if you need any more help,
Jun 13, 2010 | Singer Sewing Machines
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: . The direct link to the manual is .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: . The 4562 may use the same diagram as the 4572, .)
Jul 01, 2017 | Singer Sewing Machines
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
I have a Singer Sewing Machine Model 4562 T I
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not...
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is:
Inserting a wound bobbin is found on page 15.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
334 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
