Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sanso Shaker I bought my 7 year old niece a sansa shaker.. and all the sudden (so she says) its not working but when I try to see whats going on my computer can not decet the device... i think i need to download something.. driver maybe but i cant find where to get that? The sansa site? Does that even sound like the problem?
  • 8,596 Answers
First, make sure you are not using Windows Vista, Macintosh, Linux or any incompatible operating system
Second, check the manual and make sure the hold/lock switch is not engaged
www.sandisk.com is where you will get the driver software - it does sound like the problem
Posted on Jul 06, 2008
Replaced SD card now Shaker won't play
Hi Cathi!
Few things you need to know about Sansa Shaker and the SD card:
  1. The Sansa Shaker DOES NOT support SDHC memory cards. Only regular SD cards are supported.
  2. Maximum capacity for supported SD cards - 2GB!
  3. Any SD card which doesn't meet the requirement above might cause the problem you encounter. REPLACE the card with a supported one - SD card with up to 2GB in capacity.
  4. No software/data is stored or needed to be on the memory card - apart from your music files.
  5. MP3 file type is fully supported by Sansa Shaker.
Regards,
Pelu.
Apr 10, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
A problem with my sansa shaker
Hi again audreytagle. Please take your slip and take your sansa to the place you bought it and show them the problem they will probably give you a new one. before you do that try inserting new batteries into the sansa shaker and see if the product works. if not use the above mentioned solution.
Jul 30, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker stopped working
Hello there. i hope i am not too late with my solution. The sansa shaker has acted like yours is some numerous times but the solution can be as simple as ever. Try replacing the battery with a brand new one. However if this solution does not work simply take it back to the place you bought it with the slip and tell them your problem... they will probably give you a new one.
Jul 28, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker suddenly stopped working
Hi macys mom. try checking the audio files in the memory card through the computer. then if the are still there replace them with back up ones or just put in new ones and see if this resolves your problem. Hello audreytagle. i would advise you the same solution as macys mom and if that dose not help you get a brand new battery "energizer" to be specific. I hope i have solved the both of your problems thank you.
Jul 22, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker
Hello Cindy im KBFC id like to say that your not doing anything wrong. see i also have a sansa shaker and what i can say to you that it dosent always play all the songs in it, simply because they are not supported its quiet dissapointing but the sansa dose play most mp3`s put into it. i dont know if its a long time scince you have posted this letter but if its not too late mabyee you can still take it back in exchange for something else. HOPE I SOLVED YOUR PROBLEM BYE!
Jul 02, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker - Please Help
upgrade software the computer has to recognize device as storage device first and go threw plug and play mode
May 18, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Can't download any music onto my sansa shaker
ITunes songs are not in MP3 format.
The Shaker will only play MP3s
Dec 29, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaer
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Nov 15, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker
You should not use a program to manage your music on the Sansa Shaker. Just use My Computer to manually drag & drop files onto the device. Also, you can format the device thru My Computer, right click on the device and select format, this will erase everything on the device. Best of Luck
Sep 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
