Question about Whirlpool Microwave Ovens
Pressed light button and bulb exploded and lightening bolt shot from underneath the appliance. now it is completely broken.
  • Whirlpool Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 06, 2008
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
I have replaced the bulbs underneath the microwave, but the lights are still not working.
HELLO.
This is the solution to the problem as detailed below.
instruments needed
* Appliance bulb
* Screwdriver.
Unplug the microwave. Remove the lamp cover by unscrewing the mounting screws. Turn the bulb to tightly screw it in. Then plug the microwave back in to test the light. If the bulb still will not illuminate, it is likely broken or defective. Replace it with another 20 to 40 watt appliance bulb.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 09, 2009 | GE JVM1441 Microwave Oven
H7881 Neff Microwave Light Bulb type
go to the NEFF spares area here: http://bshappliancecare.com/Neff/neffspares.html at BSHAppliancecare - if you an locate the FD or E-Nr inside the appliance door then you are laughing. The site's a doddle to use. It should have exploded diagrams and part numbers to look up - and order. The prices seem to be fantastic for the replacements I've made (oven and fridge seals)
Nov 15, 2008 | Microwave Ovens
2001 Roper Microwave model: MHE14XKQ I pushed the light button and heard the 15 watt bulb blow-out and a lightening bolt shot out the bottom of microwave. Now it is completely dead. Does it have a reset...
Please feel free to contact me directly.
prototech@usa.net
Jul 06, 2008 | Whirlpool Microwave Ovens
Exploding microwave sounds - No Lights, No Fan, but Heats Okay
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Mar 07, 2008 | Microwave Ovens
Microwave went completely dead after changing bulb-
Nom...you probably blew the internal fuse. This time...turn off the power. Remove the button panel and search for the blown fuse. It might be ceramic or of some other type. If on a circuit board, there will be a xxxA with xxx indicating the amperage. Use a multitester available at Ace or Radio Shack to test. Replace with the same kind of unit. Your local auto store, appliance parts guy, Radio Shack or Sears parts can get you the part you need. Show them the old one.
Dec 17, 2007 | Whirlpool MH3185XP Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
