Question about Brother MFC-7820N Printer
Toner life end
I just purchased new Toner for the printer and it is telling me the toner life has ended. Any help would be appreciated.
Thanks
Eric
  • Anonymous Sep 10, 2008
    toner life end replace toner cartridge soon
    Novelist:
  • 158 Answers
Try removing the new toner cartridge from the machine, and shake it up and down and sideways, over a newspaper. Then, put it back in the machine and see if that helps. Sometimes, especially if the new cartridge was exposed to high temperatures or humidity before you got it, the toner SETTLES inside. Shaking it up can usually help.
Posted on Aug 15, 2008
Says toner life end and it's not ended. thanks. I also never reset drum button when got new drum how do i do that as well? thank you :)
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
Apr 14, 2011 | Brother DCP-8065DN Black and White Copier
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
Toner life end.
-open front cover
-press 'Option' button
-then key *00 on the keypad
-This resets the device so it knows it has had a new cartridge.
I hope it helps
Apr 11, 2010 | Brother MFC-8860DN All-In-One Laser...
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
TONER LIFE ENDED
While you have the door open, you have to press some buttons on the menu which will reset the counter. Sorry, I forget what they are right now (it's been a while since I've done it), but you can google and I'm sure you will find it.
Dec 10, 2008 | Brother MFC-7820N Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Jan 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Printer Logo
173 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
