Question about Motorola Mobility RAZR V3
Keys 3 and 6 do not work
Randomly stopped working. May be from slight water damage, only moisture / humidity though. Several keys weren't working yesterday, now its just 3 and 6. Disassembled the phone and cleaned under the keys, no luck. 3 and 6 still do not work. What can I do?
    Scholar:
  • 87 Answers
When you remove the main board, clean where the main keypad flex plugs into the motherboard. Clean the end of the flex too.
Also, if you want to try, very very slowly and carefully peel up the switches. This is the white sticker with all the little metal domes under it. You have to remove the metal keypad to do so. If you've already disassembled the phone, you should be fine with that. If you haven't broken it down that far, let me know and i will give you step by step instructions.
Also, if moisture is involved, you may want to take the outer cover off the top 1/2 and clean that upper Flex plug also.
4 T5 torx screws located under the 4 rubber bushing at each corner of the inner LCD screen. Once those screws are removed, the outer cover where the outer display and the camera lens are will pop off. Might be a little firm, but it is just snapped in. That will expose the main flex plug on the left and the camera plug on the right.
Please rate if this was helpful, or like I said, let me know if you need more detailed instructions.
91% rubbing alcohol and a toothbrush are just about the best things to use for this cleaning.
If this level of cleaning doesn't take care of it, you can try replacing the keypad flex, or it may need heatshield removal and sonic cleaning to remove any potential corrosion that may be shorting it out under the switch relay module.
Posted on Aug 21, 2008
Washed my remote key to my ford fusion what should I do
Try putting it in some white rice overnight. Rice has been know to absorb moisture out of cell phones so they work again after getting wet. It may work on remote keys as well.
Jul 12, 2013 | Cars & Trucks
Several keys stopped working on my samsung notebook,how can i fix this problem?
The keyboard unfortuneately will need need to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search to keyboard.
May 07, 2012 | Computers & Internet
Key for 2000 528i went though washing machine; after I hung it over a lamp bulb for a few hours, it worked; now, nothing
if that key no longer works but another key with the proper chip in it does then your only real choice is to replace the damaged key. Unfortunately, the waterproofing on these newer keys doesn't always work as well as it should. Even though you took steps to dry the key out the water may have damaged the contacts.
Apr 20, 2011 | 2007 BMW 525xi Sedan
5 keys are not working ( I J K M ,) on a emachines eME442 laptop
Dear Friend,
you have to disassemble your laptop for this
1 To disassemble carefully remove the keys with a small screwdriver and place in a container. DO NOT use excessive force. Remove all the keys and place in a separate container.
2 Clean the keyboard with cotton swabs lightly dampened (moisturized) with water. Replace these often and be sure they are only slightly damp. If they are too wet the excess water will contaminate the keyboard. Start cleaning. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Now wipe out full keyboard with paper napkins and then place your laptop in sunlight (3-5 minutes depens on sun) to absorbe the moisture left on the keys or keyboard.
Now assemble your keyboard again as it is earlier. (QWERTY format : for that click a photograph and copy it to your desktop so that it will not be a problem when assembling)
Thank you
Gagan Gupta
Mar 21, 2011 | Televison & Video
My "t" and "y" key randomly will not type
You could try using compressed air to move your lunch and dust/dirt from under the keys
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Too much water condensation !!! what should i do
that means it's working, It's humid out it's going to put out several pints a day possibly a gallon or 3 find somewhere for the water to go
Aug 11, 2009 | Amana PTH123B25AJ Heat Pump Air...
My key board totally shut down. What I can do ?
Has the laptop gotten Wet, Or there Maybe excess Humidity there. U can try taking it apart and cleaning the nodes where the keys touch the motherboard/membrane, also the ribbon connector into to the connecters, check and clean.. Clean this area with alcohol and a q-tip GENTLY,let it air dry and re assemble . This may or may not help your problem. because the water/moisture infiltration in the the connectors, can cause these kinds of problems. Good Luck
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Keyboard not responding or typing random letters
Sounds like the liquid has acted like a glue. You will need to get a cotton bud and dip it into some clean water. Try and clean the hole again and see if it still playing up. Also restart the computer and retry word to see if the same thing is happening.
Aug 09, 2008 | Toshiba Satellite A105 Notebook
You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
The back space one may have a link under it if it is a wide one ensure it is fitted correctly
Aug 09, 2008 | HP P2360AA Keyboard/Mouse
My Touch pad does not work, can someone help? kenmore mocrowave model 721.62624200 microwave buttons work sporatically. if i push in a downward motion they work sometimes microwave blew a fuse a couple of...
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Microwave Ovens
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
