Question about Garmin GPS
Garmin 350 power button broken - Garmin GPS
  • 502 Answers
If they don't give you a new one under warranty because of the broken powerbutton,there are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult. The part is on Ebay.
Posted on Jul 21, 2010
  • Garmin Master
  • 2,130 Answers
This is a common problem with the Nuvi series. It's a design flaw. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before.
If you would like for me to repair your GPS for a very reasonable price, please email me at KS3R at sharc dot net. I repair the unit and reinforce the switch so it won't happen again.
- Jim
Posted on Jul 06, 2008
  • SHARCNET-USA
    SHARCNET-USA Aug 13, 2008
    Note to all Garmin Nuvi 350 Users with a Defective On/Off Switch:
    1. In order to repair this problem, you need to have surface mount desoldering/soldering skills as well as the appropriate soldering tools and case dissassembly tools. Without these things, you take the risk of further damaging your Nuvi, possibly making it impossible to repair.
    2. Resoldering the switch is not going to resolve the issue long-term. In some cases, the switch can not be resoldered and additional rework must be performed.
    3. In order to fix this problem once and for all, the switch needs to be mechanically secured better to the main PCB using pre-tinned buswire. In addition, a custom-fit piece of plastic needs to be glued behind the switch to give it additional support.
    FAILURE TO DO THE ABOVE WILL RESULT IN THE ON/OFF SWITCH BREAKING AGAIN.... GUARANTEED!
    For a reasonable price, I will repair youf Nuvi on/off switch and put in the modications so it doesn't happen again. Repair takes 1 day, units are sent back the next day. Please contact me at KS3R at sharc dot net if interested. I have references.
    - Jim
2 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: garmin 350 won't turn off
Please se the aricle I wrote on this subject
http://www.fixya.com/support/r1036147-garmin_nuvi_350_360_370_660_off_power
- Jim
Posted on Nov 15, 2008
I bought a garmin nuvi 350 at a flea
Take it back and get your money back, as it is probably stolen. The PIN cannot be broken as it is set by the original user and cannot be reset by a third party. Even Garmin will not reset it without the original receipt from a Garmin dealer.
Nov 22, 2009 | Garmin nuvi 350 GPS Receiver
I have locked myself out of my garmin 350
look at the back of your garmin while power on an hold down the reset button this should take care of your problem
Jun 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 350 screen dim
press the power button quickly it should bring up a quick menu where you can adjust the brightness from... alternatively check the settings in the menu display settings
Jun 08, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Mar 30, 2017 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 power button doesn't work
buy a tom tom everyone is having trouble with garmin and its not just poert buttons tom tom is much more reliable
Aug 14, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350
Turn off mute.
with the GPS at the main screen, click the power button once. Then, click the "unmute" button at the bottom of the screen.
ta da!
Jun 07, 2008 | Garmin nuvi 350 GPS Receiver
Gqrmin 350 GPS Receiver wont turn on
Dead Battery? That makes no sense at all. He mentioned he was running it off the battery - " I was able to plug it in to a computer1.gif and unplug and was able to use it on the battery. Once I unplug and use it on battery, the only way I can power it off is by pressing the Reset button on the back."
The fact of the matter is that there is a well known issue with Nuvi 350 Power switch. I haven't taken mine apart yet (also bad power switch), but most likely the switch is defective or the solder joints are broken.
Sep 23, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
918 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
