Question about Bose Lifestyle 28 System
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
Posted on Jan 03, 2011
    New Friend:
I use smart remote on my galaxy s4
Posted on Aug 26, 2014
Ignore answer 1... they're wrong.
Logitec has a few options and they are cheaper than the overly expensive BOSE remote.
http://www.logitech.com/en-au/product/harmony-smart-control
I use this and it is easy to set up and use plus it will turn any smart phone or tablet into a remote.
Goodluck.
Posted on Aug 06, 2014
Actually you could control the bose with a harmony if you enable ir functions in bose settings
Posted on Feb 10, 2011
  • 1 more comment
  • monteb79 Mar 22, 2011
    How do you accomplish this. I have a harmony which has been great for everygthing except my Bose Lifestyle 28 system. I have a Xantech IR emitter. How can I incorporate the Bose.
  • DrWink May 05, 2011
    I am having the same issue. Did you get an answer?
  • AWAL YAKUBU Jun 01, 2011
    HI I AM USING BOSE LIFESTYLE 28 AT THE MOMENT WITH HARMONY 880 REMOTE CONTROL AND IT WORKS PERFECT. DELETE THE CURRENT REMOTE FROM THE HARMONY AND RE-INSTALL IT. WHEN INSTALLING, JUST STATE BOSE LIFESTYLE 28 ON THE DESCRIPTION AND IF THE SYSTEM ASK YOU IF YOU HAVE THE ORIGINAL REMOTE, SAY NO. THE SYSTEM WILL FIND YOU A MATCH AND AFTER THAT UPDATE THE REMOTE. YOU ARE GOOD TO GO. EVERYTHING WILL WORK PERFECTLY
    Problem Solver:
Code for remote av28
Posted on Jun 28, 2011
SOURCE:
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Dvd stuck bose ls28
Only a Bose repair technician can get the stuck CD out of the DVD ROM.
Jan 26, 2013 | Bose Lifestyle 28 Av28 Media Center With...
I have a Hitachi L32A02A TV and I need the code for a time warner cable universal remote CLIKR-5 (UR5U-8780L). The code on the back of the tv is 982, doesn't work, when I use the remote to...
You have this backwards. The applicable code would be in the Time Warner remote control. If a code search does not work, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jan 14, 2018 | Televison & Video
Need a code for the Samsung Sound Bar model HW-C450 with the Time Warner CLIKR-5 remote model URSU-8780L-TWK
I need the codes for my samsung sound bar system using timewarner remote in san diego.
Dec 24, 2010 | Televison & Video
Can't get new universal remote to work with bose av28
How old is your remote? My bose remote was prone to breaking. The RF antenna inside the remote housing tends to break away from the electronics board. I have re-soldered mine on a number of occasions. This is not a complex fix for someone who can use a soldering iron. After it happened the third time, I installed padding around the antenna so that it couldn't shake around and break free. That seems to be working so far. Hope this helps.
Dec 10, 2009 | Bose Lifestyle 28 System
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
Can not get any sound to work on my bose 28 life style system first time using it. and got a new tv
If you have no sound from any source (CDs and radio included) then check the Audio Input cable at the back of the media center. Make sure it's plugged into the top portion of the 'speakers' section into where it says "main" and not "BoseLink"
If this is fully connected, but still no audio- check to make sure your Acoustimass module (subwoofer on the floor) is plugged into a working power outlet. If that fails, try unplugging both power cords for the system for about 30 seconds.
May 31, 2009 | Bose Lifestyle 28 System
Remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
Mar 29, 2009 | Bose Cinemate Digital Home Theater System...
Can't use on-screen programming
Hmm pink clouds huh? Sound like something is wrong? I think you might want to try to contact Home Solutions and either put in for a service call or look into getting the media center repaired. I would get it repaired if it plays DVD's fine
Mar 31, 2008 | Bose RC-18S Remote Control
Lost directions on how to hook up my Bose model AV28 media center
Go to Bose' website and click on "support". See if that helps out...accordianman
Feb 26, 2008 | Bose (321GS) System
Bose Lifestyle 28 System Logo
2,307 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
