Question about Canon Office Equipment & Supplies
I have a canon image class MPC 190, I cannot get printer to work, it keeps coming up "check printer press resume #335 " can you please help me
Thanks for answering but I did ring caon and all is ok Thanks
Posted on Jul 06, 2008
I have a Canon Image Class 8580 CDW with Error E070-0000 Changed the Fuser could it be the Transfer ?
Dear
The code due to, ITB/TOP sensor defect, DC controller PCB defect.
Do the procedure to check yourself.
1. Turn off the printer.
2. Hold down the Resume / Cancel Press the POWER - indicator turns green.
3. Release the Resume / Cancel, still holding the POWER.
4. Press the Resume / Cancel 2 times while holding POWER, then release all buttons.
5. When the indicator light remains green - press the Resume / Cancel 4 times.
6. Turn off the printer button POWER. Then turn, this should solve the problem.
If the problem not clear, take the help of trained service engineer to check the connector of the ITB unit, DC controller PCB. • Replace ITB unit • Replace DC controller PCB.
Thanks.
Jan 31, 2015 | Canon imageCLASS Office Equipment &...
Canon printer MPC600F machine gives error ##335
Reset Waste Ink
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and hold the RESUME button again, the indicator
6. Release both buttons
Also you can try these steps if the first ones don't work for your model
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Mar 06, 2011 | Canon Office Equipment & Supplies
I have a Cannon Image Class MPC 190 multi function printer. I do not have the relevant soft ware. Where can I obtain it?
You can obtain the software for your printer from there website which is www.usa.canon.com. When already there, look for "Downloads" link and then select Consumer. Hope this could help you a lot. Please don't forget to rate me..:-) Thanks..
Nov 07, 2009 | Computers & Internet
Screen says waste ink near full
These are pads located directly below the cartridges while in it's resting position.These pads can be removed with tweezers and cleaned with any ink removing cleaner and then with warm water and soap,Dried and replaced.
Apr 05, 2009 | Canon Office Equipment & Supplies
Cannon multipass f80
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
Dec 10, 2008 | Canon MultiPASS F80 All-In-One InkJet...
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon printer model image class mpc 190
get the compitable updated driver cd from your vista dealer.it would be solved. many clients face this problem in vista.
Aug 16, 2008 | Office Equipment & Supplies
Mpc 190
drivers are here by model and operating system
www.canon.com
Jun 29, 2008 | Canon SmartBase MPC400 All-In-One InkJet...
105 people viewed this question
old marine
old marine
