Question about LG KU990 Viewty
I have yamaha dtxpress electro drum kit and i have found that my second tom plays sometimes even when i dont hot it .because fo the vibration...i just touch it in the bottom and it plays...what could it be?
15 dollars for telling me thant i have to change or repair the tom ...god damn....help yourself
Posted on Jul 06, 2008
Hi. I've got a problem with my hit hat controller with my Yamaha DTXPRESS III special. It is still opened, even if I strongly push on the pedal. But, when I half plug the jack in the hit hat controller it...
Sounds like the internal switch in your pedal.
Get an OHM meter, and check the continuity when you press and release pedal. Should change from Open to Short.
If not, take it to a Tech.
Nov 08, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
Sep 17, 2012 | Yamaha Dtxpress Iv Special Electronic Drum...
How do I record dtxpress 3 on garageband?
Your best bet is to get a "midi to usb" cable. is use the M Audio Uno and have had no problems, then it will record as midi, so you can edit the hits later if needed.
Mar 30, 2012 | Yamaha Dtxpress III Electronic Drum Set...
If i hit the ride bell, the tom 3 sound will come out also if i hit the crash bell, the tom 1 sound will come out also any idea how to fix it? many thanks
Is the 9ch snake cable correctly connected? TOM 3 should be plugged into the 4th input and TOM 1 should be plugged into the 2nd input. (1- SNARE, 2 -TOM, 3 -TOM, 4-TOM, 5-RIDE, 6-CRASH.........)
Jul 22, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
Can I sign four toms to my dtxpress iv? thanks Arpi
Yes you can my friend. You can even have up to four more I believe. Please read here that everything is easy to understand:
http://www.arrangerworkstation.com/forums/showflat.php?Cat=&Board=DTXpressIV&Number=441199&page=&view=&sb=&o=&fpart=1&vc=1
Take care and enjoy your DTXPRESS IV!
Nov 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Electronic snare drum pad picking up tom tom triger signal ?
your right old and new technologies are all the same basic concept, a Piezoelectric transducer converts mechanical energy into an electrical pulse. Adjust/increase the cross talk (x-talk) setting on the module for your specific channel. this settings job is to disregard really small signals (ie. vibrations from the stand, other drums etc...), you may have to play the pad a little bit harder but it should work fine.
Aug 02, 2008 | Yamaha Dtxpress III Electronic Drum Set...
LG KU990 Viewty Logo
169 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
