Question about Hoover Vacuums
I have serial U5180-910 Belt38528040 Hover Mach 3 12 amp cyclonic cleaning system. I bought it dec 2007, every time I use it stops because it over heating. what should i do about it.
    Sergeant:
    Champion:
  • 330 Answers
Take it back right away, you still have the factory warrenty.
Posted on Jul 06, 2008
(hover whisper cyclone)brush stopped rolling checked belt and looks fine what else can it be?
check other side from belt may be a little jam on the rollers on the oppsite side of the belt
Sep 27, 2012 | Vacuums
Vax mach xp reach seems clogged and light is on
Clean the filters as per the user guide AND remove the silver, where the clear plastic handle is. On te back by the purple catch to release the dirt container is a screw - remove that and then remove the 3 screws on the purple lid with holes in it, remove the lid & clean the "cyclones" - mine were all blocked. Make sure all the bits are clean & dry & re-assemble.
Jul 29, 2012 | Vacuums
My Hoover UH70040W Wind tunnell mach cyclonic has stopped sucking up debris. At the brushes you feel no suction and when you disconnect the tube on the side it has some suction but not much at all. The...
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Mar 31, 2011 | Hoover UH70040W Bagless Upright Cyclonic...
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
It shut off and will not restart
All the filters have to be removed and cleaned or replaced
Apr 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hover mach 4 vaccum
usually caused from being plugged, so first find the plug and clear it. The motor has an automatic reset, should restart after about 30 minutes, if it continues to shut off, there is still a plug.
Dec 12, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
