XP runs a disc scan when rebooting
I got home from work and noticed my computer was off. I have replaced the power supply and now when my Windows XP reboots I get a screen saying it is checking disc for problems what should I do?
    President:
  • 1,314 Answers
Let it check the disk for problems.
Posted on Jul 06, 2008
  • 2,794 Answers
Let the scan disk run. It's typical for this to happen when Windows didn't shut down properly. It's making sure that the hard drive in your computer is working properly. The bigger the drive, the longer it takes.
How do I get my Acer travelmate 2480 to reboot when I do the steps it doesn't work. A screen showed up and said reboot and press f1. Then the windows. XP shows up.
What happens when you press the power button to boot it up?
Is the system hanging and not rebooting? Try running the check disk utility?
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 15, 2012 | Acer Computers & Internet
My computer is infected by spyware this morning the wall paper in the desktop change by spyware
That is a serious virus, I have had it before. Download Avast! antivirus (avast.com - there is a free home version) and run a full system scan. If that doesn't work, you may need to completely wipe your system by inserting the windows XP disc, rebooting, and pressing whatever key your computer prompts for to boot from the CD. Then simply follow the instructions on-screen. (Perform system restore first, if that doesn't work perform system recovery)
Mar 01, 2011 | Microsoft Windows XP Professional
When I start my computer it shuts down and reboots about 4 times before it will finally start properly
Hello
A computer that constantly reboots can have one of several issues, and can be hard to troubleshoot if it will not stay on. Viruses and spyware can cause the computer to reboot continually, but hardware failure or power issues can also be the root of the problem. There several ways to approach the troubleshooting process.
Hardware failure can cause a never-ending reboot cycle; eliminate the most common causes first. Replace memory chips one at a time to rule out a bad stick of RAM. If the memory checks out, boot from the Windows CD and access the Recovery Console. Run chkdsk /R at the command prompt to check for problems with the hard drive. Remove any optional cards that were added in to the computer (such as a sound or network card) to eliminate them as the cause.
Press the F8 key while the computer is starting up to access the advanced start-up options. Select "Last Known Good Configuration," and press Enter. If that does not work press F8 again, and select "Safe Mode" this time. If you are able to access Windows in Safe Mode, disable the option to automatically restart Windows after system errors by right-clicking on the My Computer icon and selecting "Properties." On the Advanced tab, click the "Settings" button under "Startup and Recovery" and clear the check box labeled "Automatically restart." This will allow you to restart the computer without getting stuck in the reboot cycle. Ensure that your antivirus and antispyware software is up-to-date, and perform complete scans for any infections. Remove any newly installed software that may be incompatible with Windows, and update drivers for your hardware.
Replace the power cord to the computer, replace the power strip it's plugged in to, and try a different outlet. If nothing else helps, try a new power supply. Be sure to purchase one with enough power for your computer: use a high-performance power supply for a gaming computer or a lower-performance power supply for a regular workstation.
Nov 13, 2010 | Microsoft Windows XP Home Edition
How do i check disc on compaq computer
To check disc while still in windows, click on computer, right click on the "C" drive, Scroll down to properties, click on the "Tools" tab, click on the check disc button, make sure to check the box to automatically fix errors. Since the disc is in use, the program may ask you to force a dismount of the drive, hit ok and continue the scan. It may also ask you to schedule a disc scan when the system reboots, choose yes and reboot. The system will scan the disc and repair any issues.
Jul 25, 2010 | Compaq Presario 5000 PC Desktop
Blue screen of Death ?
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 25, 2010 | Dell Inspiron E1505 Notebook
Screen keeps minimizing.
Mine does it ,too.Extremely annoying! Just hit Control and 0 and it will go back to normal.
Dec 28, 2008 | Microsoft Windows XP Home Edition
My computer keeps rebooting after if reaches windows xp logo
I also have this same problem about a constant reboot of computer and what I did is I replace the Power Supply and everything is already working , becauise this problem can be link in failing power supply already...
Hope that helps..............
Oct 05, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
My SanDisc 2Gg Cruser is not working "It's DEAD", i have three computers at home one is a laptop all running Windows XP,none of them are reading the scan disc, the light doesn?t turn on and when i go to my...
Likely a power or power connection problem.
I squeezed the cruzer's connector for tighter fit to PC and that works. I also found that my laptop coming back from standby might not redeliver power to USB--PC needs restart. Also, if not already tried, plug it into another port on the machine.
Because I had to open cruzer to fix detached socket, I notice socket connection to circuit is not reinforced. If cruzer socket had been bent, there may now ba a defective connection between socket and board.
Apr 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC constantly reboot
try run windows in safe mode. then scan for virus infection.
Mar 10, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
