Question about Dryers
Heater element for whirpool dryer
How do you get the whole heater casing out of the dryer?
  • 481 Answers
  • depending on its age,
  •  at the top of the element casing there is a metal clip held by a screw.
  • older dryers require a 6" extension on a 1/4" drive ratchet with a 5/16" socket. this goes thru a small hole in the outer case to the screw holding this clip.
  • newer dryers, the screw is on the inside (where the drum is) so you have to lift the lid to get to it.
Posted on Jul 06, 2008
  • Mike Durland
    Mike Durland Jul 07, 2008
    check out this pic, it might help
My Whirpool Dryer AWD 60A take longer time to dry the clothes. I have done continuity check the on heater element and all thermostats found okay
Lint build up. Clean out where the lint trap goes in. Also clean out the vent hose. Easiest to do with a shop vac.
Jul 20, 2016 | Dryers
HOW DO YOU CHANGE THE HEATING ELEMENT ON A WHIRPOOL DRYER MODEL LE7000XTW0
The heating element is on the back side under the dust cover.
You gotta remove a strap at the top of the heater chamber and then you can get the heater assembly out. Remove the filter and raise the top:
The element is on the right
The heater
the heater element slides out after ya remove a screw at the base.
Service Manual
Oct 29, 2011 | Whirlpool Dryers
I have a whirpool dryer that is not heating model number wed5550sq0 Imperial series. I took the heater coil off. is that the only thing it could be?
On the heater element housing is 2 limits.
If either of these are open the dryer will not heat but it will run.
More Here
May 18, 2011 | Whirlpool Dryers
How to fix whirpool ler8648pw dryer, the heat is on but nothing else works?
Jun 09, 2010 | Dryers
What resistance is expected for the themostat, high cut off, and heater element, for a WED5300SQ Whirpool Elec dryer?
high cutoff should be 0 ohms or dead short like a switch, the element can vary from 100 ohms up to 250 ohms depending on the model
Dec 24, 2009 | Whirlpool WED5300S Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Dryer will turn/spin but it will NOT dry with hot air at all. It is a Whirpool WED5200TQ Dryer.
Unplug it and remove the rear cover. Check for lint in the pipes. Take the heating element off and look for broken coils. Mounted on the heater is a cupla safetys. The small one at the top is usually open IF the element turns out to be ok. This phenom is caused by a blocked dryer vent.f7a9c3e.jpg
Apr 10, 2009 | Dryers
Whirpool dryer
once you take the element casing out of the dryer then you will see a screw at the very bottom of the casing where the element goes in. usually a 5/16 hex head screw.1933c22.jpg
Jul 07, 2008 | Dryers
How do i get the heater element out of the whirpool dryer
take off the back panel, then to the right is a large vertical metal casing. depending on the age of your dryer, you either:
  1. take off the 4 screws near the bottom of the casing to release the heating element.
  2. older dryers require the whole casing to be removed and the element is slipped out of the bottom of the casing.
Jul 06, 2008 | Whirlpool Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
