I have a carrier heatpump unit. 20yrs old. the contacts need to be changed. i can't get the first spring loaded contact out. what's the trick without tear it up? this is for the a/c side.
  • 95 Answers
This is a one peice deal, the contact switch on the outside condensor that has two smaller wires and biger wires coming to it all replace together. Remember your wiring and get a whole new double pole contact switch.
Posted on Jul 06, 2008
My Air-conditioning have a carrier model no.42SD7B is problem coming error code E 03 what the problem my Air-conditioning please give me answer
Error code should have a description of Of a part or sensor next to the wiring diagram behind a panel on the unit what is it doing or not doing clean the coils change the filters check line and transformer voltage
Aug 28, 2016 | Carrier Heating & Cooling
Fix problem on carrier furnace heating blower relay click sparks click again got used mother board does same. Did I just get another bad relay or something else doing it?
It is more likely the motor or the fan causing the problem at this point [or you got a bad used board].
First with the power off try rotating the fan by hand to make sure it turns freely. If it turns hard or is stuck you know the cause. If it has places to oil the bearings, add a couple drops to both ends of the blower shaft and the motor shaft and try spinning again by hand. It could be the blower relay contacts are burned and making bad contact or possibly the motor capacitor or start windings are bad. Without a model number, I can't tell what controls your unit uses. At least Carrier is one of the better companies in providing manuals and wiring diagrams.
Carrier Literature Wiring Diagrams
If you are electrically handy, you might try energizing the motor relay without the control board connected, there should be a wiring diagram on the inside of one of the panels.
Jan 28, 2015 | Carrier Heating & Cooling
Is a carrier 38tkb024300 an AC unit or a heat pump? Heating does not work?
Yes, it should be a a heatpump...
The problem could be the reversing valve or the t-stat...those are the most common problems for them not heating if the cooling still works..
heatman101
Jul 14, 2011 | Carrier Heating & Cooling
Wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Apr 13, 2010 | Heating & Cooling
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
Brought new thermostat wired it up as stated but keeps on tripping out
Hi; Need more info what is tripping out. Sometimes the old tstat has a different wiring code than the new . Is the unit a heatpump or elec heat or gas heat with cool...alpharome416.
Feb 19, 2010 | Carrier TSTATHCP Programmable Thermostat...
Looking for auto restart on carrier 40GKX series
Can you please check if the remote handset is this?d6f691e.png if yes, follow below
• Connect the system to the electrical current.
• Press the button M and of the remote control and keep them pressed down for at least
5 seconds.
• The clock digits show the first configuration item (rAdr = remote address) and the temperature
digits show the default value of the respective configuration item (Ab = control of both indoor
units).
• Press the button M repeatedly until "ASt " appears.
• Press the buttons ∧ or ∨ to change the default value (OF) to the new value (ON).
• Press the button to send the new configuration to the unit.
• Press the button to exit the configuration menu.
To see other available configuration options, consult the table.
Item Viewfinder display Explanation Description
1 "rAdr" "A": remote unit A Remote address of indoor unit A.
"b": remote unit B Remote address of indoor unit B.
"Ab": remote units A and B Default address of the two units.
2 "UCFG" "HP": Heatpump Default address and heatpump
"AC": Cooling only Changes the cooling-only address
3 "UAdr" 1-240 with an increment of 1 Address of the CNN unit.
Default = 1.
4 "ZONE" 1-240 with an increment of 1 Zone number.
Default = 0.
5 "GFdn" 1-240 with an increment of 1 GFD number.
Default = 1.
6 "A St" "OF" : Shutdown mode Select the function mode after an
"On" : Automatic restart electrical power failure.
If no button is pressed for 30 seconds, the remote control automatically exits the
configuration menu and the entire procedure must be restarted.
NOTE
Feb 19, 2010 | Carrier Heating & Cooling
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
