Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Large gray gasket partly loose with round metal ring coming out the lower area
This problem appeared when the door was opened fully to load.
Please note: The door is never left closed when not in use.
Can I fix this myself?
  • Zarie Jul 10, 2008
    This is the answer provided by FixYa.:
    " Check the seal if its out it place check for any damage on the gasket if damaged get it replaced, if its out its place check it will placed in correct and secure it in place....."
    WHAT KIND OF ANSWER IS THIS? Does this person have any skill with the English language, let alone knowing how to provide instructions to fix a problem!!!!
    How disappointing!!! This is POOR!!!
  • Bosch Master
  • 744 Answers
BoschNexxt Premium WFMC6400UC loose gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine and how to get the parts!
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
    Genius:
  • 2,035 Answers
Check the seal if its out it place check for any damage on the gasket if damaged get it replaced , if its out its place check it will placed in correct and secure it in place.......
Please these follow the instruction given in this link:
http://www.washerhelp.co.uk/diy-repair-safety.html
Posted on Jul 06, 2008
  • Anand Kumar
    Anand Kumar Jul 10, 2008
    I am totally sorry for my English : thanks for the feed back..
    Check the seal for any damages or crack developed over the time usage...
    If its out place try push the seal back to its place ....
  • 1,512 Answers
Hi,if it has come away from its mounting band them the seal will need to be replaced.
  • 2 more comments
  • Graeme Ross
    Graeme Ross Jul 06, 2008
    I am looking for a guide for you on how to do this, back to you in a few minutes
    regards
    robotek
  • Graeme Ross
    this is from Paul_bosh here at FixYa
    It is held on by a spring that stretches around the outside of the
    seal. The seal simply hooks on to a small lip so all you need to do is
    start in one spot and push it down and away. Then just work it around
    like removing a bike tire until it is fully removed. Be careful of the
    spring. It is hooked together so it may unhook once some of the tension
    is removed and snap around.
    It is not a big deal to replace this part, you are doing the right thing leaving it open as they tend to mould up if left shut.
    I am getting a part number for you to get you replacement.
    I am more than happy to answer any other questions you may have about
    it, please get back to me here, or use the ASK function to go straight
    to me :) If you are still unsure, have problems, or we need to look at
    the situation more deeply, then before you give a rating for this
    advice, hit the ASK button
    Thanks for using FixYa, If you consider the advice I have given you as
    sound, a FixYa rating is a great reward for my efforts to help you.
    Cheers.
    regards
    robotek
  • Graeme Ross
    I did not find alot of parts supply for your model, so I suggest that you go straight to Bosch. They have an online ordering system for you to get the correct seal you need.
    Oh, and I am assuming you are in Europe... let me know if you need more assistance with getting the new seal
    regards
    robotek
  • Graeme Ross
    Graeme Ross Jul 10, 2008
    Hi, did you see my solution to your problem. The seal has come adrift from its mountings and will need to re secured into place. I have pasted it back into here for some reason you did not see it the first time.
    Comment by robotek, posted on Jul 06, 2008
    Cheers.
    regards
    robotek
    Comment by robotek, posted on Jul 06, 2008I did not find alot of parts supply for your model, so I suggest that you go straight to Bosch. They have an online ordering system for you to get the correct seal you need.
    regards
    robotek
I replaced the thermostat on my 1996 Ford Taurus Duratec DOHC 6cyl and now have a leak in the housing unit. As taken apart (I don't believe I have this messed up), I put in the gasket, then the thermostat...
You might try alldata.com, but you'll have to pay for it and it's based on the Chilton's manual. So, that may not help you.
Have you thought of using silicon gasket maker on the metal to metal part?
Aug 17, 2010 | 1996 Ford Taurus
Leaking water from underneath
The door connects to a round gasket called the "bellows". If it is torn, deformed or coming off water will leak underneath. Undo the 3 screws in the lower front panel and do an inspection of that area
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washer door leaks. How do I get a replacement seal for the door?
YOU NEED A NEW BOOT ON THE INSIDE OF THE DOOR. WHEN YOU OPEN YOUR DOOR THERE SHOULD BE A GRAY RUBBERY RING. AS A MATTER OF FACT, IF YOU MOVE THAT RING AND PUT YOUR FINGERS IN IT YOU WILL PROBABLY FIND A MISSING SOCK OR TWO! THAT RING HAS TORN AND NEEDS TO BE REPLACED.
JB
Aug 23, 2009 | Whirlpool GHW9200L Front Load Washer
Hello, my axxis washer gets mold build up on the rubber gasket at the door. i have ordered a new one but do not feel the need to pay $200.00 for the install. can i get instructions to install on my own. i...
Um...have fun. I have replaced two of them.
the way to keep the mold from growing in the future is to leave the door open so that you don't create that closed moist environment.
About the easist way to replace/change is to remove the front of the washer (I have completed w/o doing that but took a bit longer).
Make sure you keep an eye on how the old one comes off as some of them have drain pipes connected.
To remove:
There is a metal ring with a spring attached, simply streatch spring a bit at bottom of door and it should come right off. Do the same for the inside seal, that spring is at the top.
To install:
put the metal ring inside the grove of the gasket, then align gasket on the front. Pick an edge to start working around as you get closer to the top (I pick the lower right hand side to start working around. Make sure that your spring part of the metal ring is at the top where the one you replace was at.) once you get to a point you need to stretch the spring, this is where I use an 90 degree or more pick tool to get into the end of the spring. You need to make sure that you have the seal tight. Start pulling on the spring to stretching it so that can put the rest on. (You need to keep tension on the gasket so that the metal ring does not slide.)
Now to the front.
Just make sure that the spring part is at the bottom. When you took the otherone off, it was at the bottom. It has to go there as there is a groove. Once you get the metal part around the gasket push a bit on the spring and make sure it is in that goove.
To test, open and close your washer door a couple times. At first gently.
Hope this helps as they are a pain in the rear.
Also, here is a nice parts place for all your Bosch parts. www.repairclinic.com
The gasket was only about $75 to my door.
Aug 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
Water leaks out of the bottom area of the door
There is a ring that holds the door gasket in place on the outside of the front panel and another ring inside the drum (the ring has a spring on it that allows it to be stretched.
There are 2 tools that LG has that make the ring clamp easy to install/remove, but you can also use 2 pair or needle nose pliers (one to hold the ring at the spring and another to stretch the ring). Just be careful not to damage the gasket.
Also, when ordering the new door gasket, make sure you have your serial number handy. There are 2 versions of the door gasket (depending on the serial number).
Hope this helps, please rate my solution.
Jan 06, 2009 | LG WM-2277HW Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Apr 29, 2008 | KitchenAid 24 in. KUDS25 Built-in...
My washer keeps on stopping in the middle of the spin cycle
you will need to get some help to put the machine near your back door so that you can put the gray hose out side the door when all water is gone your door should open if not then you need to take your pump out and clean it out and then take the filter out it might have a sock or some thing clean it out and buy the time you have put it all back the door should of opened take any thing out of the drum put the machine back and put it on a program so some water can get in the machine then or put it on a rise and spin that will be a good program to put it on if the machine finnish then its all done.
Jan 06, 2008 | GE Energy Star WCVH6260F Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
153 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
