Need manual and charging battery tips!!! - Audio Players & Recorders
  • 3 more comments
  • wcarns Jul 06, 2008
    RCAH115A
  • EATLESSFAT Dec 10, 2008
    HOW DO I CHARGE THE BATTERY. ALSO ,CAN'T GET THE BACK OFF OF THE MP3 PLAYER.
  • Anonymous Dec 23, 2008
    Exactly the same problem, says it's charging, works on the computer but totally dead otherwise.
  • fivevillarre Dec 26, 2008
    i got a mp3 player mw3837 1gb for christmas and its not charging.every time i try to turn it on it well tell me hello and then bye,never staying on for more than 3 seconds,what im doing wrong?
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    We need your manufacturer and model # to help you with that!!!
  • 8,596 Answers
You can get manual here:
http://support.rcaaudiovideo.com/manual.aspx?product=28
Charger:
http://www.audiovox.com/webapp/wcs/stores/servlet/contact_us.jsp
Posted on Jul 06, 2008
How long to charge I only recieved it today
The initial charge will take the longest. I would give it 4 to 8 hours to fully charge.
Mar 07, 2016 | Audio Players & Recorders
Sylvania mp3 driver
The battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 03, 2013 | Audio Players & Recorders
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
Once charged , I can turn it on and thats it , can not move it at all. Charge does not last long.
Check the voltage in the charger with a multimeter,if OK then the battery must be drained off fully and recharged till it indicates.
If the charge drops off, it can be the battery itself and must be changed. It can be a possible reverrse polarity developed inside that reduces the life.Please check my profile for tips on battery life.
Replace battery .
Sep 26, 2010 | Sony Walkman NWZ-E344 Digital Media Player
My ipod touch wont stay charged i need help!?
You can do 2 things,
1. Stop charging from USB port and buy yourself a wall socket adapter.
2. Replace the battery,
And as a tip I will tell you that you shouldn't let your battery run down flat keep it charged always.
Aug 12, 2010 | Apple iPod touch 1st Generation (8 GB) MP3...
My mix max player doesn't charge
I have seen this problem before with these units. It is generally caused by not following instructions when disconnecting the unit from the usb cable. The software interrupts the charge port signal between the battery and the dci processor. The unit will function just fine and nothing will seem wrong until the battery runs out completely. There is a simple fix for this but it is not necessarily an easy one.
1. Take apart the case of the unit. The easiest approach to this is to carefully pry apart the case at the sd card port with a small prying tool or butterknife. Take care with the large clips at the ends and corners of the unit that hold it together. You will most likely break every one of the smaller case clips on the sides when the case comes open. This is fine. The case will still hold together very strong with only the larger end clips. Remove any broken side clip pieces before putting the case back together so the case will close snug and tight.
2. With the case apart, note where the battery connects to the board and unlug it. Find a small ac adapter of about 5.5 volts to 9 volts but with no more than 600 milliamps output voltage. This will need to have a recessed tip on the male adapter prong like the one pictured in this url--- http://www.elderly.com/images/accessories/ACC/PS200R.jpg --- If you have technical knowledge in electronics and the right equipment then you can use an adjustable power supply with stinger tips to penetrate the battery plug. Note on the picture that the back of the adapter tells whether the positive or negative is located inside or outside the tip. BE SURE NOT TO CROSS THE LEADS WHEN TAPPING INTO THIS CONNECTION TO CHARGE THE BATTERY!!! Once the battery has died completely and the system becomes unresponsive the dci processor and charge port resets automattically but will not charge with out some power on the battery and since the battery is completely dead you must charge it for a moment in order to get the unit to acknowledge the reset and start taking a charge on it's own. on the battery red is positive. Connect the battery leads to the adapter using small wire leads for 30 secs. Replug the battery into the units board and turn on. the unit will power up and a message will come on screen stating that the battery is low and to recharge it.
3. Immediately reassebmle units case carefully and plug in the unit to a charger/usb cord. When unit fully charges ...unplug. That's it! (NOTE: IF YOU CHARGE THE UNIT USING A USB CABLE YOU MUST CLICK THE ICON IN THE SYSTEM TRAY THAT ALLOWS YOU TO SAFELY REMOVE THE UNIT AND THEN DISCONNECT OR YOU WILL SOON BE REPEATING THE ABOVE STEPS!!!)
Aug 12, 2008 | Disney Mix Max Digital Media Player
Ipod will not hold a charge
Here are the tips to follow :
Charging your iPod battery
http://docs.info.apple.com/article.html?artnum=61127
Using the iPod Hold switch to prolong battery life
http://docs.info.apple.com/article.html?artnum=60951
iPod battery faqs
http://docs.info.apple.com/article.html?artnum=62018
Accurately determine your iPod battery life
http://support.apple.com/kb/HT1322
Tips and tricks for ipod battery
http://docs.info.apple.com/article.html?artnum=61434
If everything is fine thn its time to replace the battery
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod shuffel
iPod battery faqs
If everything is fine then its time to replace the battery
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Apple iPod shuffle MP3 Player
Will not power up
The battery is probably shot. Check voltage. if it is 0.0 then the battery has shut down internally and either needs to be charged for 48 hours, or replaced. Seems these batteries will shut themselves down to protect themselves and sometimes are never able to revive. You can try and charge it from the USB, but I dont think it does that, you need a 5.0V 2A power supply with the proper tip. I think it is a 3mm + center post. You can also remove the battery and check the pins when it is charging, It shoould show some voltage. Also, I dont think you can run it while charging.
Jan 10, 2008 | iRiver PMP-120 Digital Media Player
126 people viewed this question
 Grubhead
Grubhead
