Question about Mag Innovision M572TVs LCD Television
Screen turns on and odd
Hi, once i connect the moniter to the computer, the moniter screen just goes on and off and then i can see a very dim menu on the moniter. what is the problem?
  • 42 Answers
If the TV part works normal then you are probably trying to use a resolution and or refresh rate the monitor cannot handle. You want to be on 1024x768 max and 60hz refresh. You can try starting the computer in safe mode to test.
Posted on Jul 06, 2008
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Moniter not lighting
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 10, 2010 | AOC LM 520A 15" LCD Monitor
Power supply done but display is not
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
New moniter too dim.
Good morning! Please review the operations manual of the unit, taking note of set-up settings value requirements. best regards.
Mar 20, 2009 | Samsung SyncMaster 920NW Monitor
Oversize Message
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Moniter is black
hi sounds like you need to replace the lcd backlight which lights up your cd display when it goes you can still see things but it's very dim if you need help ordering that part let me know and i'll find you the product code hope this helps
Aug 08, 2007 | Balance CN6555 Notebook
Mag Innovision M572TVs LCD Television Logo
131 people viewed this question
Top Mag Innovision Televison & Video Experts
kj henriksen
kj henriksen
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a Mag Innovision Televison and Video Expert? Answer questions, earn points and help others
