Question about Konica Minolta magicolor 2400 Laser Printer
PRINT IS BARELY READABLE
I CLEANED THE ENTIRE SYSTEM, WITH AIR AND A SOFT CLOTH, ALL THE TONERS ARE BRAND NEW, SYTEM CHECKS OUT OK BUT THE PRINT IS FADE'D, YOU HAVE ANY IDEALS?
  • 4 Answers
There are two levers at the top of the fuser that have envelope icons on them. These levers reduce the pressure on the fuser assembly for thick stock.   If you leave them in envelope mode and run thin stock there is inadequate pressure on the fuser rollers to press the toner onto the paper.  Hence a lighter output.  I found this problem at one of my current client locations.  Hopefully this helps.
Posted on Jul 12, 2008
Oki b410d printer has a new toner cartridge however it is still printing inconsistently on the page?
Open the lid. Mounted under the lid you should see a horizontal bar which is actually the laser [LED]. Once your toner cart has emitted, enough loose toner has accumulated on the laser that it can no longer draw on the page correctly. Using something soft and barely dampened with water [use a soft cotton cloth, NO PAPER PRODUCTS, no dirty rags, etc] and wipe gently from L to R to remove the loose toner. Turn to a clean section of the cloth and do it once more. GENTLY! No pressure, do not scrub it, or you can damage the laser. Close the lid and print something. You should be back to good now.
Oct 04, 2014 | OKI B Office Equipment & Supplies
Hp CP1215 print barely visible
Check in the printer 'preferences' and see if it is set to 'draft' printing.
also check the -Advanced- tab for a possible -Toner Save Mode- option.
Tallon41
Sep 08, 2012 | HP Office Equipment & Supplies
Printing spots vertically in 2 areas on both sides of paper. no manual and can't get into it online - how do I clean whatever needs cleaning?
Open printer and remove the cartridge and check t see if there is toner spilled inside. These types of defects are often caused by a bad toner cartridge. If you do see toner inside, you can wipe it up with a soft cloth or a swiffer if you have one. Do not use a standard vacuum to clean it as the toner dust is so fine it will get into the air and into your lungs. Try a different cartridge. You may have to print 050-100 pages to clear the defect.
Apr 22, 2011 | HP LaserJet 2420 Printer
Prints with lines to the right margin of the page. How can this be corrected?
This can depend on if they are white or black lines and if you can feel a texture on the paper. Most often the cause is a bad toner cartridge. If you are using generic toner cartridges, I would suggest trying a new HP one instead to see if it clears up. If you feel a deep texture to it, the fusing unit may be wearing out and need to be replaced.
Feb 03, 2011 | HP Laserjet P4015x Printer
How do I clean the drum on a brother mfc 8860dn
Follow thesesteps : 1. Open the printer and remove the toner cartridge. 2. Inspect the drum for obvious damage. If it's damaged, don't try to clean it; replace it. 3. Remove any large spots of toner on the drum with tweezers or pliers. Be careful not to scratch the surface. 4. Dip a cotton swab in a rubbing alcohol. Gently swipe any visible soil. 5. Put a couple of drops of alcohol on a soft, lint-free cloth if the entire drum looks dirty. Carefully wipe the drum. 6 Check the other parts for dirt while you have the cartridge out. Carefully clean them. 7 Reinstall the cartridge and print a couple of test pages. If the problem persists, you probably need a new drum.
Jan 16, 2011 | Brother MFC-8860DN Printer
I need to remove the drum to clean it.
  1. 1 clean-printer-drum-1.1-120x120.jpg Open the printer and remove the toner cartridge.
  2. 2 clean-printer-drum-1.2-120x120.jpg Inspect the drum for obvious damage. If it's damaged, don't try to clean it; replace it.
  3. 3 clean-printer-drum-1.3-120x120.jpg Remove any large spots of toner on the drum with tweezers or pliers. Be careful not to scratch the surface.
  4. 4 clean-printer-drum-1.4-120x120.jpg Dip a cotton swab in a rubbing alcohol. Gently swipe any visible soil.
  5. 5 clean-printer-drum-1.5-120x120.jpg Put a couple of drops of alcohol on a soft, lint-free cloth if the entire drum looks dirty. Carefully wipe the drum.
  6. 6 Check the other parts for dirt while you have the cartridge out. Carefully clean them.
  7. 7 Reinstall the cartridge and print a couple of test pages. If the problem persists, you probably need a new drum.
Jan 03, 2011 | Brother Office Equipment & Supplies
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Printing is readable but very light
Pls refix the catridge after shaking.
Sep 10, 2009 | Office Equipment & Supplies
Printing is not clear on the right side of the printed paper. Even when a new ink cartridge is installed the printing is not very readable on the right side of the printed paper.
Ok try this...... Somewhere around the toner bottle, should be a piece of glass covering the laser from getting toner in it, remove the glass and clean it. Let me know if this works.
Apr 15, 2009 | Office Equipment & Supplies
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
Konica Minolta magicolor 2400 Laser Printer Logo
56 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
