Question about Tappan 30IN ELEC IGNa Oven
Problems... Hello, First of all where do I find the number/model of my owen? Second... it looks like the ownen is not igniting. What can be the reason for that and how this can be fixed? Thank you in advance for you time!
  • Anonymous Jul 20, 2008
    Oven does not light
I think i have an older model, TPF303AWA, and i didn't find the number under the oven, but rather i popped-up the range and it was on the rear left side.
Posted on Aug 19, 2008
My Mod# is on the very bottom of the oven, i had to pull out the broiler drawer to find. It was then on the right side about 8" in on the right.
Posted on Jul 08, 2008
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
Our oven has stopped heating to the right temperature. It does ignite and warm slightly
Hello Kathy;
My name is peter. I am a retired field service appliance technician.
It sounds like you have a bad oven control board. Don't worry. I just put in a remanufactured control board. The board was $35.00.
Purchased Locally was $256.00.
Send me the model number on your oven. Open the door and look at the metal plate. I will talk you through the part source and repair
Nov 30, 2015 | Ovens
We have had a power failure and the oven will not work unless the clock is reset but the manual instructions do not help as the knob does not change the time.
Every one of these things has a different method for changing the time/resetting the clock. You'll have to provide a make and model number.
May 29, 2015 | Ovens
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I can not provide more information.
Be careful, it may not be the igniter. It could be the Hi-Temp thermostat or some other $12.00 component. The igniter is about $35.00.
Try the following web sites
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
Mar 17, 2015 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
Oven turns on gas but doesnt ignite until theres gas build up and has small explosion. kenmore model 362.75702001
What is causing that is a weak oven igniter that is not strong enough to fully open the gas valve yet just open it a little,letting gas accumalate in the oven then finally the igniter gets to full strenght and all the gas explodes. By replacing the igniter with a new strong one it will stop that.
The igniter is pretty easy to replace. Just remove the floor of the oven and the wing looking flame spreader, the screws that hold igniter to bake burner can be removed, and disconnect wiring.Then attach new igniter to burner reconnect wires and reinstall spreader and floor .
The part number for igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
I hope i have been able to help you fix your oven,
Aug 13, 2011 | Kenmore 30172 / 30174 / 30179 Gas Single...
Hello and thank you for your help. My lower oven will not ignite while the smaller upper oven will. ?????? Thank you Rob
most likely all you have is a bad ignitor.if it glows it should ignite the flame in less than 40 seconds,if it doesn't glow,pull it out and read it out with a time send the model number.good luck.
Apr 30, 2011 | Maytag Ovens
Our Kenmore oven does not come on/heat up. I think it is the igniter that isn't working, but can't find the info on when we bought the range to know whether it might be worth having a repairman out or if...
if you open the bottom draw,on the frame you should see amodel number and serial number,all you need is a model number,most likely it will be the ignitor,pull out the racks,lift up the floor and you'll see the ignitor,first unplug it or shut down the breaker.remove the screws that hold the ignitor in place,if you don't see an ignitor it might not have one,but if it does take out the screws and pull the wires out,there should be a plug or wire nuts,disconnect them and check it with a meter,if it's bad change it out,first get back to me with the model number,if the top lifts up where the burners are the number could be up there too.don't force the top up,if it's tight and doesn't seem like it doesn't lift don't force it.
Mar 05, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
Sep 28, 2010 | Ovens
MY oven is not working. The burners and broiler do work.This is a gas oven.
If you can see the oven ignitor glowing bright orange when you turn theoven control on to say 350 degrees. (look down at the back bottom of the oven compartment near the back wall of the oven).
If there is no glow, then you have a faulty ignitor. If you can see the ignitor glowing and the owen doesn't light, then it is the thermocouple that controls the flow of gas from gas supply valve that is bad.
You'll need to replace the defective part(s) to get the oven working properly. You can find the parts on the link included along with some pricing at but you can buy parts anywhere you wish.
You'll have to pick which oven version you have as you need one more letter at the end of your model number (it's usually a small printed letter after the larger model number on the label eg: A, B, or C.) so you can look at the parts list to select the correct parts for your oven.!retrieve.pd;jsessionid=gKpqVBTSaohlK3kbhZ+WFQ**.shcapp3105?modelNumber=+FGB24S5A+&pop=flush
Hope this helps you get cooking again! Best Regards!
Jul 29, 2009 | Frigidaire FGB24S5A Gas Single Oven
Tappan 30IN ELEC IGNa Oven Logo
44 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
