Question about Toshiba Satellite A135-S4527 Notebook
I have a sony projector and I connected it with the "HD D-sub 15-pin cable" to my toshiba laptop and i have it set to "input a" but I don't know how to get the computer to respond. I mean, it just projects "input a - no input" on the screen instead of my computer desktop. Can you tell me what to do on the computer to fix this?
  • 3 Answers
1) just restart both the projector and computer it may pick up
2) when both is on press Fn key and F5
Posted on Jul 09, 2008
How do i connect my S2410-304 to a tv?
Buy a monitor cable and direct connect .we need to know what kind of tv and what kind of inputs the tv has ...Usb hd or 15 pin .let us know.
Sep 19, 2014 | Toshiba Satellite Computers & Internet
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
How to connect vga output to 3 rca tv input ?acer travelmate 2420 to panasonic tv
Do an online search for a Video cable - Male 15 pin HD D-Sub (HD-15) to M RCA
Dec 08, 2009 | Acer Computers & Internet
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
Hd outputs or connectins
The only HD input on that monitor that is true HD is the 15 pin VGA input connector. It can be set in the TV menu to be used as an RGB input OR a color difference component input (Y, RY, BY). You will need a 15 pin connector that breaks out into 3 sperate cables; the ones I've seen break out into 3 BNC connectors and then you have to use dapators to convert them to standard RCA pulgs for connection to most consumer devices.
Oct 27, 2008 | Sony PFM-42X1 Plasma TV
Connecting Ibook G4 to Sanyo PRO xtrax projector
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Feb 02, 2008 | Sanyo PLC XU33 Multimedia Projector
Sony VPL-CS4 projector
Denis, by default laptops usually output only to their own lcd panel. There must be a key combination on your laptop wich rotates output in 3 steps: lcd panel only, lcd + TV (projector), TV only. The key combination uses a special Function key (FN) usually blue (found near left Ctrl key)with one of the numeric keys. So, first make sure your laptop output is correct and then try input key on your projector.
Aug 15, 2007 | Sony VPL CS4 Multimedia Projector
Yellow-green tint
I had the same problem and found out that it was the cable from the projector to the computer. HD D-sub 15-pin cable.
Dec 25, 2006 | Sony VPL CX10 Multimedia Projector
Toshiba Satellite A135-S4527 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
