Question about Canon S520 InkJet Photo Printer
Detacted drive strip
A transparent strip became detacted from my printer. I cannot get inside my printer to see how to hook it up.
Transparent strip is: 1/4" x 12" with L on left side and:
OA4-0572-OOT
09/01CAV.006
Ruhatex
    Sergeant:
  • 287 Answers
That sounds like the indexing strip for the print head.
It may be accesible when you open the printer to replace ink carts. there will be a pin or hook on either side of the printer and you should see a slot under the print head that the strip passes thru.
the L on the strip is for LEFT this end goes to left side and there is usually a spring to keep it under tension on one end
IF this strip is damaged the print head will not move correctly and therefore not print correctly
Posted on Jul 06, 2008
A plastic strip came off the printer
The plastic strip (transparent strip) could be the encoder strip. The encoder strip is responsible for the proper positioning/movement of the ink cartridge carrier along the carrier assembly. Please contact Lexmark Technical Support Center for assistance.
Sep 26, 2011 | Lexmark X2500 All-In-One Printer
Carrier jam
To fix the carrier jam, open the printer cover. Remove the cartridges from the carrier. While the cover is open, check inside for any loose transparent strip - the encoder strip. The encoder strip ensures the proper mechanism of the carrier on the assembly. If everything looks fine inside the printer, close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and make sure they are properly inserted and secured in the carrier.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
Keep getting a carrier jam on my lexmark x6650
Try to open the printer cover and remove the cartridges. While the cover is open, check for a transparent strip(encoder strip) that may gotten unseated from its position. If transparent strip is still in position behind the cartridge carrier assembly, check the carrier path and make sure there are no debris or obstructions along its path.
Apr 24, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
P2 error
P02 (Carriage error)
  1. Make sure no foreign material stuck to the print head railway.
  2. Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.
visit this link for more info
http://pcmediks.blogspot.com/2010/10/canon-pixma-mp258-error-code.html
Dec 28, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Print Head SLAMS to right end and will not come back on lin
Sounds like a hardware issue. Open cover and check if encoder strip(transparent strip) is loose. Check for any loose connections inside the printer and see if you can manage to hook it back right. Otherwise, contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark X1270 All-In-One InkJet Printer
The transparent film strip has fallen of where does it attach to on the canon pixma mp460
The strip needs to be clean, there is an arrow on one end, needs to point up on the left side. Behind the carriage unit is a small slot that the strip passes through, a silver spring on the left to hook through the hole on the strip, and a solid metal tab on the right to hook the other hole to. It's not as easy as it sounds, especially with all the covers on...
Jun 21, 2009 | Office Equipment & Supplies
Carriage jam
hii,
try to clean film stripe between the carriage(transparent plastic)
Nov 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon S520 InkJet Photo Printer Logo
73 people viewed this question
old marine
old marine
