Question about Viking Kitchen Ranges
Digital display on Viking double oven VEDO205 went dark after a power outage. All else seems to work.
  • 1,512 Answers
Hi try pulling the fuse to the oven for 20 mins and then power it up again doing a hard reset and see how that goes.
robotek
Posted on Jul 06, 2008
  • Graeme Ross
    Graeme Ross Jul 06, 2008
    If it does not come back up, it has been affected by a power surge, or brown out associated with the power outage. If resetting it does not work, you will need to replace the control/clock assly.
    I am more than happy to answer any other questions you may have about
    it, please get back to me here, or use the ASK function to go straight
    to me :) If you are still unsure, have problems, or we need to look at
    the situation more deeply, then before you give a rating for this
    advice, hit the ASK button
    Thanks for using FixYa, If you consider the advice I have given you as
    sound, a FixYa rating is a great reward for my efforts to help you.
    Cheers.
    regards
    robotek
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
The oven will not get hot on the self-clean option, but it will get hot when just using the regular oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 26, 2010 | Viking VEDO205 Electric Double Oven
I did the self clean on the upper oven. When the stopped cleaning it cooled down, but the door will not open. (Unlock)
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 15, 2010 | Viking VEDO205 Electric Double Oven
I am replacing the lower oven baking element. After pulling the defective one out, I find no female receiver for the male connection tabs on the element. Are they loose wired? I am used to just plugging...
They probably are loose wired unless you see a porcelain receiver for them... it is CHEAPER so they do it! Maintainability? None !!!
With power disconnected, you MIGHT be able to "fish" the leads back out and attach before mounting the element.
Oct 17, 2009 | Viking VEDO205 Electric Double Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Kitchen Ranges Logo
110 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
