Sony STR AV 370
Hello, I have an oldish Sony STR AV 370 receiver/ amplifier - it will work for a while and then stops producing sound and starts flashing a red "p" light. At this point you can also hear something clicking inside. turning it off at the wall for a while and then trying again seems to fix it. Sometimes it will work with no problems all day and other times just won't come to the party at all!
I would be grateful for any advice you could give me.
Jim
  • 1,512 Answers
Hi jimec
The flashing of the power light indicates that the unit is going into Protection Mode. The relay clicking inside is the speaker protection relay disconnecting the speakers to prevent any damage to them, or any further damage to the amplifier. When you turn it off, it cools down the fault is rectifying itself, and the unit can functionally normally. The most probable cause of this sort of fault, is dry/ cracked solder joints about power regulators, or audio output stages. If you attend to this before the amp stops working altogether, then you may save some money in more expensive part replacement type repairs.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 07, 2008
How do u reset soney reciver str-dg510 i have no sound
What preceded this? Was it working and then stopped or did it never work?
http://www.retrevo.com/support/Sony-STR-DG510-Receivers-manual/id/2526ci754/t/2/
Page 26...
Press I/O to turn off the receiver
Hold down I/O for 5 seconds (("PUSH" and "ENTER" apear on the display alternately)
Press MEMORY/ENTER. After "CLEARING" apperas on the display for a while, "CLEARED" appears.
Jan 31, 2011 | Sony STR DG510 - AV receiver - 5.1 channel...
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Feb 07, 2010 | Sony STR-DE597 Receiver
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Hello. my sony receiver is flashing protector mode and no sound is coming out. how do I fix this? thanks, Suzanne
More than likly the built in amplifier is dead and its time to lay it to rest. Before you do that, make sure all your positive and negitives are correct and that none of the wires are touching one another.
Jul 24, 2009 | Sony STR-DE705 Receiver
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
"PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Feb 06, 2009 | Audio Players & Recorders
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
1,488 people viewed this question
 Grubhead
Grubhead
