Samsung LN46A580P6F LCD HD TV It is not hooked up to a PC, just satellite. The screen is black and the power light is blinking continuously. It makes a "click" sound, ever minute or so, as if it is turning on. Can't get the tv to turn on or off. Any help would be appreciated. -thank you
    Problem Solver:
  • 8 Answers
The problem is most likely your power supply. The easy way to check is to pull the back cover off (make sure the tv is unplugged) an check the capacitors on the power supply board. If they are bulged or appear to be leaking anything then replace them with the same rated and size capacitors. My LG did the same thing. Local repair shop said I would need over $80.00 in parts alone. I got them for less than $12 (I ordered extras) from Digi-key. Replaced the bad with good and tv works like brand new. If you are unsure if you can handle it do a youtube search for samsung or replacing a capacitor and you will see how easy it is to fix.
Posted on Mar 07, 2010
I have the exact same tv and it is doing the exact same thing. I have only had it for about a year and 2 months, which means its out of samsung's warranty. Were you able to fix the problem?
Posted on Jan 04, 2010
I suspect you have to select the correct Source. Do this from the Source button on the remote, then go up and down the list til you see the one that works
Posted on Oct 19, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
Samsung LN46A580P6F LCD HD TV is turning on and off from two to ten times before it stays on when the tv is cold
Samsung LN46A580P6FX
On the main board, IC104 (Part #SPX1587AT) is a 3.3VDC to 1.8VDC regulator. When this IC fails, the 1.8VDC drops substantially when the TV is turned on. After five minutes or so, the unit operates fine. This IC can be purchased from digikey for about $1.80.
Another fix is to attach a 1000uF 10 volts capacitor from ground to the DC source of this IC. I used a 1000uF 50V (overkill) for proof of concept. See attached pictures.
Dec 17, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Mar 24, 2017 | Samsung LN-S4695D 46 in. LCD HDTV
Televison & Video Logo
727 people viewed this question
Top Televison & Video Experts
