Question about Sony CDX-F5000 CD Player
Rear speaker out?
My display on the deck will have "REAR LINE OUT" when the deck is off. Is the line from the deck to the speaker out, or is it the speaker itself? I know it sounds stupid. All rear speakers are out though.(Doors and rear headline) I have a '99 Tahoe.
Leon
How to replace rear shocks on a 86 Toyota celica gts?
This procedure can be found at autozone.com. You can register for free, listing make, model, year, and engine size. Find procedure under "repair guides". Good illustrations, too.
1. On liftback, remove rear speaker grilles. On coupe, remove suspension service hole cover or the speaker board (on rear deck by back window).
2Drum brakes or disc brakes? No matter: Do not break apart the brake lines. There is a clip on the strut to hold the brake line and it's connection to the rubber brake hose. Take the c-clip off and cut the brake line retainer with a hacksaw (careful of the brake line and hose). This way you won't have to worry about bleeding the brakes when done. Take the line out of the strut retainerclip. When re-installing, just use a zip tie to hod the brake line secure.
3. Loosen, but don't remove, the 19mm nut holding the suspension support to the strut (this is the larger center nut on top of strut at the deck by rear window.
4. Disconnect stabilizer bar at lower end of strut housing. You will need a 14mm wrench and a 3/16 (or equivalent metric size) allen wrench to hold the link steady while removing the nut.
5. Disconnect strut at the axle carrier-17mm size bolts.
6. At top, remove the three strut to body nuts-size 13mm., and remove the strut.
To put your new struts inside the coil spring, you will have to have a spring compressor. I don't have one, so after removing strut, took to a shop for that, cost was $20 for one side. Picked it up and installed it myself.
To install: Position assembly and tighten the upper strut to body nuts to 23 ft. lbs.
2. Tighten lower strut-to-carrier bolts to 119 ft. lbs..
3. Connect stabilizer bar to strut. Tighten the nut to 26 ft. lbs.
4. Tighten top strut holding nut to 36 ft. lbs. (the shop had already done this for me) and install dust cover.
5. Reconnect brake line and hose, and bleed the brakes, if you broke the line apart. If you didn't break the line apart and just cut the clip retainer, you will not have to bleed the brakes.
6. Lower the car and have rear wheel alignment checked.
If you have a spring compressor, and can do that procedure yourself, the instructions for it are found at autozone.com, along with the above that I have outlined.
Jun 03, 2012 | 1986 Toyota Celica
I am putting in a new stereo system and I need to know what color wires go to the speakers
If your installing a new stereo deck you should get a wire harness from walmart $10-$20..
this will make it easy work!! the harness will have labeled wires.
If you cut the wires then i need the make and year of the car to help more.
On the new deck most have the same colors..
the 2 white.. front left
greens rear left
grays front right
violet rear left
remember the wires with the black line is the - ground
Jul 14, 2011 | Car Audio & Video
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-P4100
I have a jvc KD-G320 deck and need help hooking up subs...
Hello c92bivens,
While your KD-G320 does not have a specific subwoofer output, Kenwood did make provisions for adding one. There are two stereo pairs of line outputs on the back, one each for front and back. On the set for the rear, you can select a "line output mode" of "REAR" for normal speakers, or "WOOFER" for operating a sub.
Page 14 of your owners manual details the setting procedure while page 31 shows the connections. The manual incorrectly refers to the FRONT line outputs on page 14. Use the REAR line outs instead. If you do not have a manual, you can download the PDF version here at Crutchfields's web site. Ignore the "DISCONTINUED" notice (it's an old head unit), and scroll down the left just under "What's in the box" and click the "download owners manual" link.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | JVC Car Audio & Video
I need to see the cable configuration for car radio CQ-JS7580k ( corolla CD/radio car)
It tells you on the top of the deck or lables on wires. the front speakers are white= + and white with a black line= - and grey+
grey with blak line= -.rear are green and purple
Mar 02, 2009 | Kenwood KSC-WA82RC Car Subwoofer
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Sony CDX-F5000 CD Player Logo
376 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
