Question about Coby Audio Players & Recorders
Coby mp3 player isn't recognized by windows - Coby Audio Players & Recorders
  • 8,596 Answers
Do you have Vista? If so, get the Vista-compatible software from coby's website - if they even have any
If you have XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
Thank you you're a gentleman, genius and a scholar. fixed my coby mp c683 the holdling the volume + button did it thanks phil the old hippie
Posted on Jul 14, 2008
SOURCE: Charging the coby clip 1gb m582 mp3 player
MINE HAS NO SWITCHS JUST THE USB PORT AND I CANT GET IT TO CHARGE
Posted on May 27, 2008
  • 6 Answers
SOURCE: Charges But Doesn't Recognize
Ok First, Open Your MP3 player2) Go To Setup
3) Then Go to system
4)Then Usb Mode
5) there will be auto or MSC
6) choose msc and then plug it in the files will be there.
Posted on Apr 13, 2009
SOURCE: coby mp3 mp-605-4g is not recognized by any computers
I have the same problem. If you turn the unit over, you can see a small hole on th bottom right hang side - (next to USB symbol) - The RESET button is located inside. If you insert a small paper clip and press the button for approx 20 seconds it should function again.
Works for me
Posted on Dec 04, 2009
  • 29 Answers
SOURCE: Coby 610 MP3 not powering up or being recognized when plugged in
The same thing happened to me. Have you tried resetting it? Open up a paperclip and poke it in the back hole. The mp3 should reset. If this doesn't work, you are going to have to reformat it, although I did not have to do that so I don't know how.
Posted on Feb 13, 2010
  • 89 Answers
SOURCE: My computer won't recognize the
check wether your mp3 player is turned on when it is connected to the pc. if not turn it on. if it doesn.t work try another usb po
Posted on Dec 31, 2010
Drivers for Coby MP3 player model no MP550-2G. I have windows XP
Having Operating System Windows XP, most mp3 players can be recognized in Windows Media Player 11 software from Microsoft.
How to use WMP11 look on next site:
http://www.microsoft.com/windows/windowsmedia/player/11/using.mspx
You can also use Coby Media Manager from the manufacturer for media transfers. See next page for how to download and install Coby Media Manager, for XP download the execute file coby-mediamanager-2009b0924.exe on next site:
http://www.cobyusa.com/?p=fix_mp822
After download and installation, run Coby Media Manager:
select Tools > Device Manager...: select MP-550 from the list:
click Add : click OK to have the MP-550 as your operating device.
Under Device Configuration you can set the synchronizing location and
bitrate conversion for audio.
Need more help ? Just add a comment.
Apr 10, 2010 | Coby MP550 MP3 Player
My PC does not recognize the COBY MP-610 MP3 Player
Following these instructions for fixing your Coby Mp-610 MP3 Player will replace the brains in your mp3 player, and allow it to be recognized by your PC.
Dec 22, 2009 | Coby MP-610 MP3 Player
Computer doesn't recognize mp3
Following these instructions for fixing your Coby Mp-610 MP3 Player will replace the internal programming of your mp3 player, and allow your computer to recognize it.
Nov 22, 2009 | Coby MP-610 MP3 Player
Windows not Recognizing COBY MP705-8G
Make sure you have plugged your Coby MP3 player into a USB 2.0 port. The Coby does not support the USB 1.0 standard. If you are getting an error that "This device can perform faster..." your port is an older USB type. I have both types on my computer and the Coby would not install until I plugged it into my 2.0 port.
Hope this helps.
Jun 26, 2009 | Coby MP-705 Digital Media Player
Usb malfunction
I can help you with you Coby 610 mp3 player.
What is happening is that your Coby isn't communicating properly with the computer. You don't need a driver, you just need to repair the Coby's system software.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 16, 2009 | Coby MP-610 MP3 Player
To be rocognized by windows 98
http://www.download.com/COBY-MP-C440-MP3-Player/3000-2120_4-88061.html
Mar 01, 2009 | Coby MP-C582 MP3 Player
Coby mpc7095 2gb player has lots of songs on it but PC won't pick them up
I changed the settings in system tools >USB settings to MCS mode and then you can access all lthe files on your coby player through your PC and move them into the appropriate folder. It seems all your music has to go into the music folder. The Coby player isn't the most user friendly and is buggy. If they fix the programming, it would be a good competitor to ipod.
Mar 04, 2008 | Coby MP-C7097 MP3 Player
382 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
