Question about Whirlpool Dishwashers
ADP 8966 dishwisher the top washer inside appears to be not revolving when washing appears to be static? http://www.fixya.com/lpregister2.aspx?brdid=2099&cmpid=5270208113882&ctgid=0 Get Assistance
    President:
  • 1,462 Answers
Spray arm jets probably blocked. assuming you can rotate the spray arm by hand and it is free, take spray arm out and clean.
Posted on Jul 06, 2008
Light are on but not operating. The agitator revolves slowly.
Need more info model # on washer brand name will help as well
must be a top loader
Mar 23, 2015 | Washing Machines
Put to many towels in and now it will put water in but no spin
If motor revolves (the heard noise) , but drum no, that you necessary to change the belt.
Jan 03, 2011 | Kenmore 23822 Top Load Washer
Water leaks when washer is filling up
The hoses are locted in the back do not open the top you may need to just replace the hoses,check intake selenoid
Jul 05, 2010 | Maytag MAV7580E Top Load Washer
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Hi I have a Hotpoint Bwm20 washing machine that will not go into spin cycle, it doesn't appear to be draining down. I've cleaned out the filter and overflow and all is clear. Please help? thanks
Isolate from electrical supply.Remove plinth which gives access to drain pipe and pump - drain, remove plug and and any debry, then check that pump revolves freely. Remove top and ensure that the tube connected to pressure swich isnt blocked.
Mar 08, 2010 | Hotpoint BWM20 Front Load Washer
Not washing
first check to make sure the water supply line to the unit, isn't kinked and the valve is completly open. then i'd try using a solvent that removes calcium deposets[clr or something similar] in with a few cycles. then i'd start looking for a motor.
Sep 19, 2009 | Asko D1716 Built-in Dishwasher
The revolver in the middle isn't spinning.
I assume that the machine is a Kenmore / Whirlpool direct drive, top load with neutral drain and that the "revolver" is actually the agitator.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
1. The motor coupler
#13 on diagram Coupling, motor and isolation Number:3364003Substitution:285753A $18.50
In stock may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
If it spins and drains OK, and if you can hear the motor turning, the problem points to the transmission.
Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of them may have either broken or worn out.
There is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as for your washer. On it is a list of all of the components and parts for the washer.
By paging down to and following the diagram of the transmission you should be able to determine
which actual part is broken.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Sep 07, 2009 | Kenmore 22422 Top Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Dishwashers Logo
153 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
