Question about Sharp 56DR650 56" Rear Projection HDTV
PROBLEM WITH MY TV SHARP 56DR560
My tvis making a loud noize and the color fades on the screen too.
how color wheel look like?
    Problem Solver:
  • 3 Answers
Your problem is the color wheel. the load noise is comming from the color wheel motor. there is an article here on how to take the color wheel out. what you need to do it follow those steps and take the motor apart and clean it without breaking it and put thin high temp grease on the axle of motor and put it all back together. that will fix the loud noise and the fading of the screen. i know because i am an electrician and i fixed my shap tv. any questions just ask
Posted on Feb 23, 2009
  • 80 Answers
Here are pix - wont fix but showes how to changehttp://www.instructables.com/id/How-to-fix-your-Sharp-56DR650-with-color-wheel-iss/
if you need the wheel email me at nipper00@gmail.com
Posted on Aug 29, 2008
    Problem Solver:
  • 8 Answers
Use those instructions and then go here to buy a replacement So glad I did this, fixed the TV and the wife is very happy! Go to Encompass Parts http://www.encompassparts.com/ Where it says login, click on the words "guest login" and you won't have to register. Click on US Dollars at the next window. In the next window, copy paste this part number - 3250701500 and click the little magnifying glass. Don't worry about model number. Checkout and yours will be on the way. Mine was $102 shipped! The brand is Vivatek and it works perfectly! Thank you to whoever posted this! We found another for over $189 but decided to try this. I kept pulling the old one out, cleaning and oiling which would last only a few weeks and got tired of it. Anyone who needs help installing please email me at scott.d.krieger@gmail.com and I will help you out. The TV is worth repairing. We plan to get a spare in case we need it. Hope this one lasts longer than the original wheel.
Posted on Apr 27, 2010
I have a issue with my rca scenium hd61lpw164yx1 tv ...i have replaced the bulb about a year ago. my screen started not coming on instantly it started fading in and eventually would not come on at all.i...
When the color wheel starts to go there is a high pitched whinning sound, the humming could be from the light engine or ballast, which may or may not be related to the color wheel. I would have to see it and test things for a correct diagnoses, but it does at least sound like a color wheel in the last moments of its life
Jul 16, 2011 | Televison & Video
My Samsung's picture is starting to fade and all the colors are turning a reddish color. Does this mean I need to change the lamp? I just did that about 6mos ago. What now?
with TV on bring up the menu. If the menu screen is NOT affected, the DMD board should be fine. It menu is affected, DMD board is likely the reason.
Also check the color wheel, sometimes when they are going bad they will translate the wrong colors or even make a loud pop and shut TV down. If the bearing is going bad on color wheel, it can make a grinding/squealing kind of noises and sometimes even make the TV vibrate.
Im not a TV specialist. Just trying to help with what I have experienced with this set.
Feb 27, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
Color is terible and can fix it
This DLP tv have a colors wheel.Ur tv colors wheel is dead.When u have black & white picture,colors fade in and out.The tv make loud squiling or loud motor noises.All these problems are related to the colors wheel.Hire a tv repair Tech. for this job,because the colors wheel,require take out alots of machanical's parts out even before to get to the colors wheel to replaced it.
May 29, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Sharp 56DR650 Rear Pro. TV. w/ a LOUD color wheel motor
If the color wheel is making noise then its best to replace it and not try to repair it, Unfortunatley the wheel is not available by itself and a complete optic block part # 9NK3797086200...Be careful when taking the bock apart as it runs $900.00
Oct 14, 2009 | Sharp 56DR650 56" Rear Projection HDTV
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
607 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
