Question about Motorola Mobility H700 Wireless Headset
Motorola Bluetooth Headset H700
I've had this headset sitting in my car for about a year, and now I'm trying to use it because of the hands free law, but I can't get it to work...I tried chargingit with my blackberry charger, and it lit up like it was charging, but won't do anythiing after I unplug it. I charged it for probably 8 hours. So I guess I just need to know if I can fix it or if it's broken for good.
  • dukezl Jul 07, 2008
    yes i have the same problem. had it sitting in a bin in my room for 6 months or something and just tried to use it. when i plug it in the light is solid green but for the life of me i can't get it to do anything when its not plugged in. I press the call button, I move the mic boom, the whole deal. Could this simply be a user error? Or has Motorola irresponsibly created yet another defective product? Anyways, assuming this product isn't a timebomb, any suggestions would be greatly appreciated. Thanks!
  • Anonymous Dec 02, 2008
    Same here. And i also havent used it before and i got my phone ages ago. I think it has something to do with not using it for a period of time. What ****.
    Scholar:
  • 125 Answers
Have you gone through the "pairing" steps to get the phone and H700 unit to recognize each other? Unless the two are paired with each other they won't communicate with each other.
Posted on Jul 11, 2008
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
Bluetooth serial # 6809501a26-0 need
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'. 4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Sep 01, 2010 | Motorola Mobility H700 Wireless Headset
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Motorola blutooth
the factory defualt pin is 0000
Sep 30, 2008 | Motorola Mobility H700 Wireless Headset
Broke the ear hook for the Motorola h500 bluetooth headset
I searched on google for motorola h700 and found plenty of sources? Amazon.com and others.
Aug 30, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
50 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
