Question about Fuji FinePix S3 Pro Digital Camera
Hotshoe problem I have a problem with the hotshoe , Flash is hard to attach to hotshoe. Hotshoe will not trigger flash. synch will fire flash and built in flash works.Do you think that replaceing the hotshoe will cause the shoe to work?
I have not soved this problem. I do not need your assistance since you tricked me into giving you my e-mail address and letting you know my situation. After all of this you asked for a signup fee. You should have gave me all this info about fees before I started.
Posted on Jul 06, 2008
Nikon d700 hotshoe missfire with flash nikon sb900
Probably a loose hotshoe. This is a common problem with the D700 hotshoe and SB900 combo. The weight of the SB900 eventually loosens the hotshoe, meaning the internal screws holding the hotshoe in place loosens.
Nov 13, 2012 | Nikon D700 Digital Camera
Vivitar 283 won't fire
Since the flash is working on test, it means the connection to the camera via the hotshoe is not working. With the flash on and ready light showing that the flash has charged, take a small thin copper wire and short between the the metal spring on the side of the hotshoe (in the slot) and the round metal contact tip of the hot shoe. This should cause the flash to fire if the internal connections to the shoe are working.
If the shoe is working then it must be the camera that is not working. Many modern digital cameras cannot fire older flashes directly, because the voltages on these older flashes are too high. This could damage the camera or if the camera has protection against the high voltage, that will make it impossible to fire the flash. In that case you need an adapter. These are available cheaply. You should try borrowing a modern flash to test that your camera is still working and has not been damaged, if it is a modern electronic camera.
Nov 26, 2017 | Vivitar 283 Flash
Ok. If I use the AS 15 or any other hotshoe attachment.
The problem isn't with the AS-15, it's with the flash units. The trigger voltage on those units is too high for use with DSLRs without protection such as the Wein Safe-Sync.
Apr 03, 2012 | Cameras
Hye! can we use umberella lights with this cemers kodak z612 ?
To use umbrella lights, you need a hotshoe connection on top of the camera to attach a radio transmitter. This would set off the umbrella lights. Some high-end DSLR cameras do this very well.
Sep 14, 2010 | Kodak EasyShare Z612 Digital Camera
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Unwanted flash fire in nikonD200
Hi, I had the same sort of problem. It started with erratic small flashes but then evolved to the SB-800 not regonizing the D200 at all. The result of this is that I only get TTL and not TTL+BL+FP functionallity.
To solve this I cleaned the hotshoe on the D200 with all purpose cleaner for electical appliances (CRC 5-56). This gave minor improvment. Then I adjusted the spings to the left and right on the hotshoe on the D200 to press harder against the flash's connection (which I suppose is the grounding). Now everything works again.
Best regards,
Marcus
Jun 21, 2008 | Nikon D200 Body Only Digital Camera
Mecablitz76 MZ5 remote
If you are using Pocket wizard you attach a hotshoe to pocket wizard adapter to the unit that usually fits on your camera hotshoe and attach this unit as usual to the 76mz5. There are various brackets that can secure and tidy the whole thing but you can manage without them if you wish. I got the paramount hotshoe to pocket wizard mini jack to do this £35 each from TFC and the bracket to fit the 76 MZ5 to a stroboframe bracket from speedgraphics at £17 and a one to fit the TTL controller to the 76mz 5 keeping it all tidy in all it cost £67 but makes a neet little unit that can be mounted on a stand and if you want to spend another £25 you can even attach a brolly. Great as a studio flash unit
Feb 28, 2008 | Metz mecablitz 76 MZ-5 TTL Flash
Beginner with Studio Lights
will need more information, but the basic idea is to connect the trigger on top of your camera's hotshoe, and then connect the receiver to the flash.
Feb 11, 2008 | Cameras
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Fuji FinePix S3 Pro Digital Camera Logo
566 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
