Question about Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100 My projector when powered on has indicator go from red to green and lamp is also on with display coming ok. However after about 10 to 15second lamp goes off and power indicator keeps blinking green with no display. Also on the side lamp cover alarm orange indicator keeps blinking. When powered off and on again same story again. Let me know if there is any inhouse solution for me to make it work. thanks.
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Posted on Jul 07, 2008
Blue dots
http://www.nodevice.com/user_manual/sony/projectors1/vpl-ds100.html
Use this link to download your manual troubleshoting tips, to see if problem referred on.
Aug 09, 2008 | Sony VPL-DS100 Multimedia Projector
Lamp is not working
How many times is the red light flashing at one time? The flashing is an error code, the number of flashes indicated the problem. It could be the bulb, the fan, a power issue, or even your altitude.
Mar 02, 2014 | Sony VPL-EX100 3LCD Projector VPLEX100
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
How do I reset the lamp timer on the Sony VPL-DS100?
Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
Apr 18, 2009 | Sony VPL-DS100 Multimedia Projector
Lamp Cover will not close fully
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
Dec 13, 2007 | Sony VPL-CS7 Multimedia Projector
Sony VPL-DS100 Multimedia Projector Logo
456 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
