Samsung NV10 Digital Camera Logo
Posted on Dec 26, 2010
Camera beeps three times when you try to turn it on and will not turn on.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
60
Points
Beacause the eyes is blocket just drag it and it will run normally
Samsung Digimax S800 camera won't turn on. Beeps three times.
This explains the 3 beeps. also says you can get it repaired which is by far the best option. The behaviour is very typical of low battery state. Try a set of Lithium batteries.
https://www.samsung.com/in/support/cameras/why-camera-goes-off-after-3-beeps/
3helpful
Insignia camera turns on beeps three times and turns back off
Three beeps indicates a low battery or other warning. It also indicates error messages, such as memory full or card error. You should try replacing the batteries, erasing files from the memory, or verifying that your memory card is in the correct format and/or not defective. Additional details can be found in the owner's manual.
2helpful
2answers
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
2helpful
2answers
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
3answers
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
1helpful
2answers
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
