Question about Microsoft Xbox 360 Console
E74 failure my x box has gone into meltdown i have one red flashing light in the right hand section i can only find a solution to the 3 red flashing ring problem please advise. thank you
    Scholar:
  • 29 Answers
The cause of the E74 Error might be overheating of your console and for avoiding such error messages in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling the console such as cooling the machine through a pedestal fan etc. But as your Xbox already have E74 Problem, You can either send your Xbox to Microsoft for repair ( just for your information Microsoft is no longer providing Extended warranty for E74 Problem), Microsoft generally takes 3-4 weeks to fix the problem. If you can't wait for a month (I know most XBox gamers can not wait without their favourite Gaming device), You can also fix E74 Problem yourself and that too within an hour without any technical knowledge. I would suggest you to check out the DIY Xbox Fix Guide for more information.
Posted on Mar 14, 2009
I HAVE E74 PROBLEM ONE RED LIGHT IF NOT RING OF DEATH WHAT IS IT?
Posted on Jul 06, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Line is on "no lines rings"
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Sep 22, 2010 | Lucent PARTNER18 Corded Phone
I do not know how to turn the ringer on
Press the right hand intercom once. The display should say Centralized Programming.
Jun 15, 2010 | Lucent PARTNER18 Corded Phone
My xbox is got a e74 system error what is it an can i repair it
It's a known failure on the XBOX 360 and Microsoft will cover it even after the device has gone out of warranty.
Excerpt from About the E74 Error:
...the E74 error message can indicate the general hardware failure that is associated with three flashing red lights error on the console. As a result, we have decided to cover repairs related to the E74 error message under our three-year warranty program for certain general hardware failures that was announced in July 2007. We have already made improvements to the console that will reduce the likelihood of an occurrence of this issue. Detailed information related to the Xbox 360 warranty and resources for those who require repair can be found at http://www.xbox.com/support (http://www.xbox.com/support) .
Apr 29, 2010 | Microsoft Xbox 360 Console
My xbox is flashing three red lights and the error code E74 is appering
your Micro$oft xbox is broken - return to manufactureer
Dec 07, 2009 | Microsoft Xbox Console
Red ring on console
As you didn’t state how many red lights are on your Xbox i will post all the Red ring of death errors.
All sections red (4 Red Lights) = Could not detect the AV cable. Check all of the cables at the back of the console.
3 Red lights (Sections 1, 3, 4) = General hardware failure. Contact Microsoft Support.
2 Red lights (Sections 1, 3) = Overheating. Make sure that your console is in a well-ventilated area with a good air flow and try again.
1 red light (Section 4)= Hardware failure. This is usually combined with an error code on screen. Contact Xbox support.
Nov 17, 2009 | Microsoft Xbox 360 Console
Ring options
Sep 26, 2009 | Lucent PARTNER18 Corded Phone
My xbox 360 wont open and if i play it for like 30 mins at an average it gets the 3 red lights.i think it wont open because a few months ago my dads girlfreinds moms dog came over and while my dad was...
hi
those red lights are the rrod(red ring of death)if still under warranty send back to microsoft its the cheapest and safest way to garuntee that the problem is solved just be sure to keep on there cases as they have a dendency to take a while hope this helps
Sep 07, 2009 | Microsoft Xbox 360 Console
Wat do the different types of rings mean for the red ring of death
This page will tell you the meaning of the lights on the xbox360
http://support.microsoft.com/kb/907536/en-us
If you look on the right hand side of the page in the section "view related content" it gives you links for explanations of 2,3 & 4 lights
1 red seems to be a genrealised hardware failure
2 red , system is overheating
3 red problem with power supply
4 red A/V cable isnt plugged into the back properly
Jul 27, 2009 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
89 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
