Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Solo baric l7 WOOFER... CAN I REPLACE THE VOICE COILS?
I HAVE TWO 10 INCH SOLO BARIC L7 WOOFERS. THE YELLOW CONE ON ONE IS TORN. SO I DON'T THINK THAT COULD BE FIXED. THE OTHER WOOFER.... ON OF THE VOICE COILS CAME LOSE...CAN I FIX THAT ONE OR WHAT OR DUE I HAVE TO BUY NEW SPEAKERS.....AND ARE THESE SOCALLED REFURBISHED SPEAKERS A SCAM?? BECAUSE I KNW KICKER DOESN'T REFURBISH THEM
    Scholar:
  • 173 Answers
Polyurathane will fix any speaker trust me my l7 came apart compleetley and i glued it al back with urathane and its bangin hard now and has ben for 6 straite months
Posted on Sep 14, 2008
Well you can bring it into the place you bought it.. or a place where they sell kicker brand subs.. and ask them for a fix..
they'll either order you another one or.. they'll send it to be fixed.. depends on what it is(note) kicker L7 is made to be taken apart and fixed
Posted on Jul 28, 2008
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How can i check if one voice coil is burned out on a sub woofer.dual voice coil
hi there, looking from the back with the S the right way round, put a meter across the two terminals on the left + and - to check the first coil, then same on the right, if it shows o/c then youll know which one if duff!
hope this helps
Sep 21, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Where can i get a mojo 15 reconed
You'll find out it will cost you way more to rebuild the woofer than to replace it.
Jul 29, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need the basket gasket for 15'' l7
The only way to get a new one is to contact Kicker directly, and see if they'll sell you one. Otherwise, you'll need to get another woofer. They only sell the replacement parts for the SoloX woofers. Sorry about that.
Apr 28, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No sound
Check The Wire Connection And Backtrack It All The Way To The Headset And Power Supply It May Be A Connectivity Problem But If Not You Will Have To See if You Can Have Your Speaker Serviced if Not You Will Without Dout Need To Replace It
May 09, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
406 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
