Question about Kbyte 2GB PC6400 DDR2 Laptop Memory
Memory upgrade for my Acer extensa 5420
I have 2gb of DDR2 What's the most i can put in this labtop 2 slots i have and have 1gb in them each.. What kind do i use? does the mhz matter for speed what is the best i can use? Help me please
  • 426 Answers
You should be able to use 4gb, but you need to check the specs on your laptop....
Posted on Jul 06, 2008
I WILL REPAIR MY COMPUTER
Upgrade your RAM into 1GB or more, currently you are using 512MB which causes your system slowdown. On that model look for SoDIMM RAM with the DDR2 slot with 1GB or more. If you can see 2 memory slots, just buy additional RAM then put it on the blank slot.
Oct 06, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Can the memory be expanded?
Your Satellite A205-S5000 System Specs Memory:DDR2 PC2-6400, DDR2 PC2-5300icon_detail.gifMemory Type: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-6400, DDR2 PC2-5300 with a maximum of 1GB per slot.
Sep 12, 2012 | Toshiba Satellite A205-S5000
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
Upgrade to 3GB in laptop?
yes you can install 1GB in one slot and 2GB in other slot. but you have to make sure that the RAMs must have the same BUS speed.
Please make rating to my answer
Sep 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Extensa 4620 memory upgrade
According to the manual up to 4gb on two .soDIMM for model ex4220 only.SO yes. I would  take them back and get one 2Gb strip. Download and read the manual first, in case I missed somethng.
Your User Manual: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/c434e20d60a3befe482573560024cc6e?OpenDocument
Jan 19, 2009 | Acer Extensa 4620 Notebook
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Kbyte 2GB PC6400 DDR2 Laptop Memory Logo
441 people viewed this question
Top Kbyte Computers & Internet Experts
David Payne
David Payne
Are you a Kbyte Computer and Internet Expert? Answer questions, earn points and help others
